You are here: Point Clouds > PointCloudExpressionEvaluator
Evaluates expressions, such as algebraic operations or conditional statements, to set point cloud component values.
Expression Syntax
An expression consists of a combination of operands, operators, and parentheses. For example, a simple expression might be:
(@Component(x) + @Component(y) + @Component(z)) / 3.0
This expression calculates the average of the x, y, and z components.
White space may be used between the operands, operators, and parentheses as it is ignored by the expression processor.
Types and Overflows
This transformer attempts to avoid overflows by changing data types through the course of evaluating an expression. For example, if two UInt8 values are added together, the internal computations will be performed with a UInt16 type; this ensures that no overflow will occur.
In general, performing an arithmetic operation on integer types will produce an integer type. The exception to this is division: it will always produce a floating-point result. Performing an arithmetic operation on floating-point types will always produce a floating-point type.
Note that when converting between different data types, a Bounded Cast is used. As a result, when a calculated value does not fit in the destination data type, the corresponding destination value will either be set to the minimum or maximum value possible in the destination data type.
Transformer Categories
Calculated Values
Point Clouds
FME Licensing Level
Search FME Knowledge Center
