You are here: Web > DropboxConnector
DropboxConnector
Accesses the Dropbox file storage service to upload, download, or delete files and folders or list the contents of a folder from a Dropbox account.
Jump to Configuration
  • Manage datasets on Dropbox by uploading, downloading, and deleting files and folders
  • Transfer a file's contents (such as XML or raster) into or out of an attribute in FME
  • Read downloaded Dropbox data using the FeatureReader, or upload data written by the FeatureWriter to Dropbox
  • Retrieve file and folder names, paths, links and other information from Dropbox to use elsewhere in a workspace.
The DropboxConnector uses your Dropbox account credentials (either via a previously defined FME web connection, or by setting up new FME web connection right from the transformer) to access the file storage service.
Depending on your choice of actions, it will upload or download files, folders, and attributes; list information from the service; or delete items from the service. On uploads, link attributes are added to the output features. On List actions, file/folder information is added as attributes.
  • This transformer cannot be used to directly move or copy files between different Dropbox locations. However, multiple DropboxConnectors can be used to accomplish these tasks.
The remaining parameters available depend on the value of the Request > Dropbox Action parameter. Parameters for each Dropbox Action are detailed below.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies Dropbox account
FME Licensing Level FME Professional Edition and above
Aliases DropboxCaller
History
Categories
Integrations
Web
FME Knowledge Center
Search for all results about the DropboxConnector on the FME Knowledge Center.
