You are here: Workflows > AttributeFileReader
AttributeFileReader
Reads the contents of a file and stores them as the value for the specified attribute.
Note that if necessary, full pathnames can be created from existing attribute values by using the StringConcatenator to prepend folder names and/or append extensions prior to using this transformer. The resulting attribute can then be used to specify the source file.
Transformer Categories
Attributes
Format Specific
Workflows
Search FME Knowledge Center
