You are here: Calculated Values > LeftRightSpatialCalculator
Computes relative position of Candidate input features relative to Base input features.
The geometry of a Base feature is restricted to lines.
See the example below. The Base lines are considered to be oriented from the start point to the end point (digitization sense). A Candidate feature is:
  • located to the LEFT of a Base feature if looking down the Base line in the direction of the orientation (from start to finish);
  • located to the RIGHT if the Candidate is on the right of a Base feature;
  • UNDEFINED if the Base and Candidate features intersect, or if the Base feature has a single point.
Transformer
Transformer Categories
Calculated Values
Search FME Knowledge Center
Tags Keywords: relative position
