You are here: Filters and Joins > LineOnAreaOverlayer
LineOnAreaOverlayer
Performs a line-on-area overlay. Each input line is split at any area boundaries it intersects.
Transformer
Attribute Accumulation
If attributes on the incoming and original feature share the same name, but are not geometry attributes that start with fme_, then they are deemed conflicted.
Generate List
Each resulting piece receives the attributes of the area(s) it is contained in, and each containing area receives the attributes of the line.
Aggregates are not supported by this transformer.
Example
Transformer Categories
Filters and Joins
FME Licensing Level
Search FME Knowledge Center
