You are here: Rasters > RasterTiler
RasterTiler
Splits each input raster into a series of tiles by specifying either a tile size or a number of tiles.
Note: Alternatively, you can use the Tiler transformer. The following table compares the Tiler and the RasterTiler:
  Tiler RasterTiler
Type of data accepted All types Raster only
Tile size units Ground coordinates Pixel coordinates
Tile row numbering (0, 1,...) Bottom to top Top to bottom
Supports forcing equal-size tiles No Yes
Supports raster index attribute No Yes
Supports number of horizontal/vertical tiles attribute No Yes
Example
Transformer Categories
Rasters
FME Licensing Level
Search FME Knowledge Center
Tags Keywords: raster grid band clip tile subset
