AttributeFilter
Routes features to different output ports depending on the value of an attribute. The set of possible attribute values can be entered manually, or extracted from an input source in the properties dialog.
- Separating features based on attribute values for further individual processing
- Extracting one or more groups of features from a dataset based on attribute values
- Selecting features from a dataset that match specific values and discarding the rest
- Grooming a dataset by keeping select features and discarding features with non-matching, empty, missing, and/or null values
Once connected, the AttributeFilter lets you select an attribute to filter incoming features by. By default, Empty, Missing, Null, and Unfiltered outputs are provided, and you can specify additional values to filter by either entering them manually or importing values from an existing dataset.
All features are passed through the transformer, exiting via the appropriate output port.
In this beginning of a workspace, a CAD file containing road data is read, and the features divided into separate streams for further processing based on the autocad_layer attribute value.
The transformer has been connected to the incoming features from the Reader, and so the dataset’s attributes are available for selection. The autocad_layer attribute is chosen.
The desired values are entered, each on a separate row. The available values could also be determined by using the Import button to scan the contents of the dataset.
- Ideally, you will want to keep the filter list fairly small; otherwise you can end up with a very long list of attributes. If FME determines that the list might be too large, it will return a warning.
- If feature filtering can be done with groups or ranges of values, consider using the TestFilter or AttributeRangeFilter.
- If you are filtering features for the sole purpose of writing to separate layers or datasets, consider using Fanout instead.
| <Empty> | If the feature’s attribute value is an empty string, the feature is output via the <Empty> port. |
| <Missing> | If the feature does not have the specified attribute, it is output via the <Missing> port. |
| <Null> | If the feature’s attribute has a value of null, the feature is output via the <Null> port. |
| <Unfiltered> | If the feature’s attribute has a value not in the list, the feature is output via the <Unfiltered> port. This port can be used for collecting all features with "positive" values, that is, values that are not missing, null, or empty. |
For each value entered in the Possible Attribute Values list, an output port is created with the same name as the value.
| Attribute to Filter by |
When you connect the transformer to the feature type, the list of attributes will appear in a pull-down list. Choose the attribute from the list. |
If you know the values you wish to filter, enter them individually here, one per row. Each entry will create an output port.
You may also import values from a source dataset by using the Import button.
Dialog Options
Enabled once you have clicked on a row in the Possible Attribute Values list. Choices include:
Note: you may not remove the default values of Empty, Missing, Null, and Unfiltered. |
The import button launches a wizard which will populate the Possible Attribute Values list with a set of values read from a dataset. Select a dataset, the feature type(s) to read from, and the attribute to be scanned for possible values. On completing the wizard, existing values are added to the list. |
| A set of control characters is available in the Text Editor. | |
| Working with User Parameters | Create your own editable parameters. |
| History | |
| Categories |
FME Knowledge Center
Search for all results about the AttributeFilter on the FME Knowledge Center.
