FME Transformers: 2026.1
Categories
Rasters
Related Transformers
Clipper
RasterMosaicker
RasterSubsetter
Tiler
WebMapTiler
RasterTiler
Jump to Configuration
  • Dividing a raster into smaller rasters
  • Reversing the action of a RasterMosaicker
  • Tiling rasters to match the extents of additional datasets to enable group processing
  • Tiling data to facilitate parallel processing
The RasterTiler accepts raster features, and divides them into smaller tiles according to the parameter selections.
Tile size can be defined by specifying tile dimensions in cells/pixels, or by specifying the number of tiles to create, both vertically and horizontally.
In either case, the tiles are measured from the upper-left origin (0,0) position. If tiling by Tile Size, the origin can be offset (Seed Column and Seed Row).
If the specified tile size results in partial (smaller) tiles along the right or lower edge, the Force Equal Sized Tiles option can pad smaller tiles with cells to match the full tile size.
Attributes may be added to the output tiled raster features, including an original raster index, row and column positions, and tile counts.
RasterTiler or Tiler?
The Tiler transformer also tiles rasters, and may be appropriate if you wish to tile based on ground coordinates instead of pixels or tile number division. This table compares the two:
  Tiler RasterTiler
Tiling extents
Cumulative over all features
Single feature
Type of data accepted
All types except surfaces and solids
Raster only
Tile size units
Ground coordinates
Pixel coordinates
Tile row numbering (0, 1,...)
Selectable
Top to bottom
Supports forcing equal-size tiles
No
Yes
Supports raster index attribute
No
Yes
Supports number of horizontal/vertical tiles attribute
No
Yes
Choosing a Raster Transformer
Creating and Modifying Boxes and Rectangles
Creating rectangular geometry is a common task. These transformers do so in a variety of ways.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the RasterTiler on the FME Community.
