FME Transformers: 2026.1
Categories
Geometries
Related Transformers
2DBoxReplacer
2DGridAccumulator
2DGridCreator
BoundingBoxAccumulator
BoundsExtractor
Creator
HullAccumulator
HullReplacer
MinimumSpanningCircleReplacer
RasterExtentsCoercer
BoundingBoxReplacer
Jump to Configuration
  • Determining the extents of individual features
The BoundingBoxReplacer receives features with any geometry type and individually replaces their geometry with one of:
  • 2D Bounding Box - the minimum enclosing rectangle, with sides parallel to the x and y axes.
  • 2D Oriented Bounding Box - rotated to fit the feature as tightly as possible while remaining a rectangle.
  • 3D Bounding Cube - the minimum enclosing cube for 3D features, including point clouds. The cube is axis-aligned.
Requesting 2D bounding boxes for 3D features produces footprints. Requesting a 3D bounding cube for a 2D feature produces a 2D box.
If an output bounding box or cube has zero area (if the input feature is a single point or vertical line, for example), it will become a point or line as appropriate.
Feature attributes are retained.
Creating and Modifying Boxes and Rectangles
Creating rectangular geometry is a common task. These transformers do so in a variety of ways.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the BoundingBoxReplacer on the FME Community.
