FME Transformers: 2026.1
Categories
Geometries
Related Transformers
2DBoxReplacer
2DGridAccumulator
BoundingBoxAccumulator
BoundingBoxReplacer
BoundsExtractor
Creator
RasterExtentsCoercer
RasterTiler
Tiler
2DGridCreator
Creates a regular grid of points or rectangular polygons of a specified size, position, and coordinate system.
Jump to Configuration
  • Creating reference grids
  • Creating clipping polygons
The 2DGridCreator creates a single grid of regularly spaced features, which may be composed of:
  • rectangular polygons,
  • points at the corners of each cell, or
  • points at the center of each cell.
Cell size is specified by Column Width and Row Height, in the units of the specified Coordinate System.
A Starting Corner is selected (Lower Left is the default), along with a Starting X and Y Coordinate. Grid cells are calculated and numbered from this point accordingly for a specified number of columns and rows.
This transformer does not receive input features.
Creating and Modifying Boxes and Rectangles
Creating rectangular geometry is a common task. These transformers do so in a variety of ways.
This transformer has no input ports.
Processing Behavior
Not applicable.
Feature Holding
Not applicable.
Dependencies
None
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the 2DGridCreator on the FME Community.
