FME Transformers: 2026.1
Categories
Calculated Values
Related Transformers
BoundingBoxAccumulator
BoundingBoxReplacer
HullAccumulator
HullReplacer
MinimumSpanningCircleReplacer
PointCloudPropertyExtractor
RasterExtentsCoercer
StatisticsCalculator
BoundsExtractor
Extracts a feature’s minimum and maximum coordinate values into attributes.
Jump to Configuration
  • Determining a feature’s extents as attribute values instead of geometry.
The BoundsExtractor receives features with any type of geometry and individually extracts their minimum and maximum x, y, and z coordinate values, storing them as attributes.
Where coordinate values do not exist (such as z values on 2D geometry or non-spatial features) a value of zero (0) is assigned.
To exclude an attribute, leave the parameter blank and it will not be added to the output features.
Feature geometry is unchanged.
  • Point cloud extents need to be recalculated after some operations. Consider using the PointCloudPropertyExtractor and its Calculate and Update Extents parameter instead.
  • To extract minimum and maximum values on attributes, use the StatisticsCalculator.
Creating and Modifying Boxes and Rectangles
Creating rectangular geometry is a common task. These transformers do so in a variety of ways.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
  Search for all results about the BoundsExtractor on the FME Community.
