FME Transformers: 2026.1
Categories
Geometries
Related Transformers
2DBoxReplacer
2DGridCreator
BoundingBoxAccumulator
BoundingBoxReplacer
BoundsExtractor
Creator
RasterExtentsCoercer
RasterTiler
Tiler
2DGridAccumulator
Creates a regular grid of points or rectangular polygons that span the extents of all input features.
Jump to Configuration
  • Generating grid for a specific dataset’s coverage
  • Creating reference grid in conjunction with a Tiler or RasterTiler
The 2DGridAccumulator receives features with geometry and creates a regular grid that covers the bounding box containing all features.
The grid may be composed of:
  • rectangular polygons,
  • points at the corners of each cell, or
  • points at the center of each cell.
Cell size may be either specified explicitly in ground units or calculated based on the number of cells desired both horizontally and vertically.
Columns and rows are numbered and may start in any of the four corners of the features’ bounding box.
If the cell size is explicit, seed coordinates for x and/or y may be applied to adjust the grid’s position.
Creating and Modifying Boxes and Rectangles
Creating rectangular geometry is a common task. These transformers do so in a variety of ways.
Processing Behavior
Group-Based
Feature Holding
Yes
Dependencies
None
Aliases
2DGridReplacer
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the 2DGridAccumulator on the FME Community.
