FME Transformers: 2026.1
Categories
Geometries
Related Transformers
2DGridAccumulator
2DGridCreator
RasterTiler
WebMapTiler
Tiler
Jump to Configuration
  • Tiling data for storage or processing efficiency
  • Tiling data to match the extents of other datasets to enable group processing
The Tiler accepts features with most types of geometry, including vector, raster, and point cloud. 2D and 3D features are supported. The input features are divided into a series of rectangular tiles, according to parameter selections.
The extent of each tile may be described by:
  • Dimensions in Ground Units - where the height and width of the tiles are specified explicitly in the ground units of the features’ coordinate system, or
  • Number of Tiles - where the bounding box encompassing all features is divided by the specified number of columns and rows.
Features receive Column and Row number attributes identifying the tile they fall within. Columns and rows are numbered from zero (0) and the numbering may start in any corner.
Features are split where they cross tile boundaries. Elements that fall on tile borders may be duplicated in each tile.
Seed coordinates can be used to control tile position when Define Tiles By is Dimensions in Ground Units.
3D features are tiled as they overlay the 2D tiles. Where they are split, z values may be interpolated in a variety of ways. Measures may also be interpolated where required.
RasterTiler or Tiler?
The RasterTiler also tiles rasters, and may be appropriate if you wish to tile based on number of cells (pixels) per tile. This table compares the two:
  Tiler RasterTiler
Tiling extents
Cumulative over all features
Single feature
Type of data accepted
All types except surfaces and solids
Raster only
Tile size units
Ground coordinates
Pixel coordinates
Tile row numbering (0, 1,...)
Selectable
Top to bottom
Supports forcing equal-size tiles
No
Yes
Supports raster index attribute
No
Yes
Supports number of horizontal/vertical tiles attribute
No
Yes
  • Features in a latitude/longitude coordinate system may need to be reprojected prior to tiling. Consider using the Reprojector or other reprojection transformers. For temporary reprojection for defined tile size, the CommonLocalReprojector may be useful.
  • The Tiler does not create grid. For grid, see the 2DGridAccumulator or 2DGridCreator.
Creating and Modifying Boxes and Rectangles
Creating rectangular geometry is a common task. These transformers do so in a variety of ways.
Processing Behavior
Group-Based
Feature Holding
Yes
Dependencies None
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the Tiler on the FME Community.
