FME Transformers: 2026.1
Categories
Geometries
Related Transformers
2DBoxReplacer
BoundingBoxAccumulator
BoundingBoxReplacer
BoundsExtractor
HullAccumulator
MinimumSpanningCircleReplacer
RasterExtentsCoercer
HullReplacer
Replaces feature geometry with a convex or concave hull around the feature.
Jump to Configuration
  • Generating hulls around individual features
The HullReplacer receives features with any geometry type and individually replaces their geometry either a Convex or Concave hull.
A convex hull is a polygon covering the extents of the feature, where no interior angle is greater than 180 degrees. It resembles an elastic band surrounding the feature.
A concave hull (or alpha hull) has no restrictions on angle and may follow the general shape of the feature more tightly. It is calculated using the Alpha Value parameter and can have multiple parts and donuts.
If an output hull has zero area (the hull of a single point or vertical line, for example), it will become a point or line as appropriate.
3D hulls may be generated when input features are either 3D or a mix of 3D and 2D. If mixed, 2D features are assigned a default Z value.
Concave hulls and alpha values
Concave hulls vary in shape. They are calculated by first triangulating the dataset, then measuring the circumradius of the resulting triangles (the radius of a circle that touches all three points of the triangle). Triangles that are larger than the specified Alpha Value are discarded, and the rest are dissolved to form the hull. Measurements are in ground units.
If the Alpha Value is explicitly specified, it is used for the calculation. If it is zero (0) or not specified, the alpha is approximated as the smallest value that produces a single area. If the alpha is too small it may return a null geometry. Larger numbers generally produce larger areas, and a large enough alpha value produces the same result as a convex hull.
See Examples below to see the effect of varying the Alpha Value.
Geometries that are farther away than Alpha Value from the rest of the geometries may be discarded if they do not constitute a valid area on their own.
Concave hull generation works best with points, but line and area geometries will be accepted and converted to points if input.
  • Point clouds are considered single features. To create a hull from a point cloud’s individual points, use a PointCloudToPointCoercer beforehand, setting the Output Geometry parameter to either Single Multipoint or Individual Points.
  • For triangulated surfaces, see the SurfaceModeller, Triangles output.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases ConvexHullCreator ConvexHullReplacer
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the HullReplacer on the FME Community.
