FME Transformers: 2026.1
VectorOnRasterOverlayer
Rasterizes vector or point cloud features onto an existing raster. For vector features the fme_color attribute sets pixel color, and point clouds may be rendered using their color or intensity components.
- Imprinting vector data onto an existing raster background (such as orthophotos)
- Updating a raster image from vector data
The VectorOnRasterOverlayer receives vector geometries (points, lines, areas) and/or point clouds, and rasterizes them onto an input raster feature, producing a single output raster.
For vector input features, the fme_color attribute determines the pixel color in the raster. Pixel values for red, green, and blue bands will be taken from the corresponding component of a feature's fme_color attribute. Pixel values for gray bands will be the average of the fme_color components.
Polygonal features may also optionally have an fme_fill_color attribute; in this case, the outer boundary will be drawn using fme_color and the inner area will be drawn using fme_fill_color.
For point clouds, pixel coloring may be done using either the color or intensity component.
The Z coordinates of the input vector features are used to generate pixel values for numeric bands.
Line weights are not supported, and features will be drawn at a width of one (1) pixel. Lines and points may be buffered prior to entering the transformer to increase their visibility.
Alpha value and anti-aliasing options are available. The resolution, extents, and interpretation of the output raster will be identical to the input raster.
Vector data extents do not need to match the extents of the raster - if they extend beyond the raster, they will be clipped.
Attributes from the input vector or point cloud features may be merged onto the output raster, with a list attribute option available.
Features with no color attribute (or point clouds without an intensity component, if selected) will be discarded and output via the <Rejected> port, as will extra or invalid raster images.
Aggregate rasters are not supported, but they may be deaggregated and mosaicked prior to entering the transformer. Aggregate vector data may be rasterized, but may produce duplicate records if a list attribute is created.
Rasters with palettes are not supported.
This transformer supports raster band selection. The RasterSelector can be used to modify selection.
In this example, we will overlay a set of park polygons on an orthoimage.
Note that the extent of the Parks dataset covers a much larger area than the orthoimage.
The parks and input raster are routed into a VectorOnRasterOverlayer.
In the parameters dialog, we enable Generate List, name the list attribute ParksInArea, and select a single attribute - ParkName - to be added to the list. The remainder of the parameters are left as their default settings.
The output raster has the park polygons rendered on the image, and they have been clipped beyond the extents of the input raster. Note the list attribute containing the names of the parks that have been included.
- To rasterize vectors/point clouds and create a new raster (not drawing on an existing one), use the ImageRasterizer.
- To add labels, you can use a Labeler and TextStroker prior to the VectorOnRasterOverlayer.
- For fine control over cartographic styling, consider using the MapnikRasterizer.
- If your background raster spans more than one image, use a RasterMosaicker prior to the VectorOnRasterOverlayer.
- To produce elevation rasters, use the NumericRasterizer.
- To increase size and visibility on vector features, consider using the Bufferer.
- To colorize a point cloud from a raster, use the PointCloudOnRasterComponentSetter.
- If a raster has a palette, use a RasterPaletteResolver prior to the VectorOnRasterOverlayer.
Choosing a Raster Transformer
Working with Rasters
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
Vectors and Rasters
Vector or point cloud features to be rasterized. Vector features must have an fme_color attribute. Point clouds must have either a color or intensity component.
Raster to use as the background of the output raster. Unless Group By is being used, only one raster will be accepted. Aggregates are not supported.
This must be a raster feature or an error will occur.
The raster drawn from a group of features.
Invalid features will be routed to the <Rejected> port.
INVALID_VECTOR_GEOMETRY_TYPE
INVALID_VECTOR_GEOMETRY_INTERPRETATION
INVALID_VECTOR_GEOMETRY_COLOR
INVALID_VECTOR_GEOMETRY_DIMENSION
EXTRA_RASTER_FEATURE
Group By |
If the Group By parameter is set to an attribute list, one raster per group will be produced. |
Complete Groups |
Alpha Value (0-1) |
Specify the alpha channel value (0-1) for the vector features, where 0 is fully transparent and 1 is fully opaque. |
Composite Using Alpha Band |
If Yes, rasters will be expected to have an alpha band selected. Vector features will then be blended with the underlying raster according to their alpha values, rather than just overwriting the underlying raster. |
| Anti-Aliasing |
If Yes, the output lines will be smoothed using an anti-aliasing algorithm. |
Tolerance |
The Tolerance parameter is the maximum normalized distance from a line segment or polygon vertex to a pixel to be rendered. For example a tolerance of 1.0 will draw all pixels touched by the input vector line, while a tolerance of 0.0 will draw only those pixels where the input vector line passes directly through their center. Tolerance can only be selected when anti-aliasing is off. |
Input Component |
When drawing point clouds on color bands, the Input Component specifies which component of the point should be used to set the color of the raster pixel. If Color, the points in the cloud must have a color component. If Intensity, the points in the cloud must have an intensity component. The intensity component is converted to a color using a grayscale continuum, where the minimum intensity in the cloud is black and the maximum intensity in the cloud is white. |
Merge Attributes
If enabled, attributes from the overlaid vector features will be merged onto the output raster.
Accumulation Mode |
Merge Vectors: Attributes from all features will be merged, and in case of conflicts, the value of Conflict Resolution will be used. Prefix Vectors: Incoming attributes will be presented with a prefix set in Prefix parameter. Replace with Single Vector: Only attributes from vectors will be used. |
Conflict Resolution |
This parameter is enabled when Accumulation Mode is set to Merge Vectors. Use Raster and Use Vectors will give priority to the raster and vectors respectively in case of attribute conflicts. |
Prefix |
The value is used as a prefix when Accumulation Mode is Prefix Vectors. |
Generate List
When enabled, adds a list attribute to the output raster feature, and the attributes of overlaid features are added to that list, in order of appearance.
List Name |
Enter a name for the list attribute. Note List attributes are not accessible from the output schema in FME Workbench until they are exposed with an AttributeExposer or processed with a transformer that operates on them, such as a ListExploder or ListConcatenator.
Add To List |
Selected Attributes |
Enabled when Add To List is set to Selected Attributes. Specify the attributes you wish to be included. |
Yes |
Search for all results about the VectorOnRasterOverlayer on the FME Community.
