FME Transformers: 2026.1
Categories
Cartography and Reports
Rasters
Related Transformers
3DForcer
DEMGenerator
ImageRasterizer
MapnikRasterizer
RasterCellValueCalculator
RasterDEMGenerator
RasterExpressionEvaluator
VectorOnRasterOverlayer
NumericRasterizer
Creates a numeric raster representation of vector or point cloud input features, where cell values are taken from the z coordinates of the input features and overlaid on a uniform background.
Jump to Configuration
  • Creating single-band numeric raster representations of vector data
  • Rasterizing vector polygons as a precursor to raster algebra
  • Not used for generating DEMs or overlaying vectors on an existing raster
The NumericRasterizer receives point, line, area or point cloud geometries, and “draws” them onto a numeric (single-band) output raster feature.
Input features must have z coordinates. The cell values for the rendered input features are taken from their z coordinates, and the remainder of the raster is filled with a single specified Background Value, which may also be designated as the raster band’s Nodata value.
The size of the output raster may be defined by number of rows and columns, or by specifying the size of a single cell (pixel) in ground units. The geographic extent covered by the raster may be either determined by the input features or manually specified.
A variety of options is available for raster interpretation type. Anti-aliasing may be used to smooth lines.
The input features are discarded.
If vector features (such as polygons) overlap, then the value of the cell in those overlaps comes from the last feature to arrive.
Rendering non-elevation values: 3DForcer
Vector features often represent non-elevation data. To produce a numeric raster representation of those vectors with a NumericRasterizer, the value to be represented needs to be stored in the z coordinate of the source data.
To accomplish this, use the 3DForcer transformer prior to the NumericRasterizer, and assign the desired values to the features’ z coordinates.
  • To rasterize vector or point cloud features into a color raster, consider using the ImageRasterizer or MapnikRasterizer.
  • The NumericRasterizer does not interpolate cell values as might be required when using point-based features such as elevations or weather stations. If interpolation is required, consider using the RasterDEMGenerator, DEMGenerator, or SurfaceModeller.
  • To carry out raster algebra on rasterized polygons, use either the RasterExpressionEvaluator or RasterCellValueCalculator transformers.
  • To rasterize vector data onto an existing raster feature, consider using the VectorOnRasterOverlayer or MapnikRasterizer.
  • When rasterizing point clouds, all points are processed, in the order they occur within the point cloud. Depending on the resolution of the raster, multiple points may fall within a cell. As all are processed, the last point encountered within a cell will provide the band value. The PointCloudSorter may be useful to prepare the point cloud.
Choosing a Raster Transformer
Processing Behavior
Group-Based
Feature Holding
Yes
Dependencies None
Aliases Rasterizer
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the NumericRasterizer on the FME Community.
