FME Transformers: 2026.1
Categories
Rasters
Related Transformers
RasterBandInterpretationCoercer
RasterPaletteInterpretationCoercer
RasterInterpretationCoercer
Alters the interpretation type of rasters, including all bands, and converts cell values if necessary.
Jump to Configuration
  • Changing raster interpretation type to meet format or processing requirements.
The RasterInterpretationCoercer receives raster features and converts all bands based on a chosen Destination Interpretation Type. Choices include:
  • RGB24
  • RGBA32
  • RGB48
  • RGBA64
  • Gray8
  • Gray16
  • Red8
  • Red16
  • Green8
  • Green16
  • Blue8
  • Blue16
  • Alpha8
  • Alpha16
  • UInt8
  • Int8
  • UInt16
  • Int16
  • UInt32
  • Int32
  • UInt64
  • Int64
  • Real32
  • Real64
Options are available to control the manner in which cell values are converted, handling color to color, numeric to color, color to numeric, numeric to numeric, and floating-point to integer conversions.
Band names, if they exist, are retained.
Multi-Band Rasters
When converting to an interpretation with multiple components, such as RGB and RGBA, the input raster will be expected to have exactly 1, 3, or 4 bands. If only one band is supplied, it will be cloned to create the correct number of bands for conversion to the chosen interpretation.
When converting to a single color or numeric interpretation, multiple input bands will be averaged into a single one. Note that changing the bit depth (scaling) and averaging cannot be performed at the same time - they must done one after the other.
Palettes
If bands selected for conversion contain palettes, the destination interpretation must be an unsigned integer - UInt8, UInt16 or UInt32 to accommodate the palette keys.
Choosing a Raster Transformer
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the RasterInterpretationCoercer on the FME Community.
