FME Transformers: 2026.1
Categories
Calculated Values
Rasters
Related Transformers
RasterBandMinMaxExtractor
RasterBandPropertyExtractor
RasterStatisticsCalculator
RasterPropertyExtractor
Extracts the geometry properties of a raster feature and exposes them as attributes.
Jump to Configuration
  • Extracting basic information about a raster feature, such as geographic extents and origin point, cell spacing, number of bands, and more.
The RasterPropertyExtractor receives raster features, and extracts basic information about their geometry. The results are added as attributes, and output with the original feature.
The transformer has no parameters.
Property attributes include:
_num_bands
_num_rows
_num_columns
_spacing_x
_spacing_y
_origin_x
_origin_y
_rotation_x
_rotation_y
_min_x
_min_y
_max_x
_max_y
_cell_origin_x
_cell_origin_y
_upper_left_x
_upper_left_y
_upper_right_x
_upper_right_y
_lower_right_x
_lower_right_y
_lower_left_x_lower_left_y
  • This transformer extracts only raster geometry properties. To extract band and palette properties, such as band names, interpretation types, and palette information, use the RasterBandPropertyExtractor.
Choosing a Raster Transformer
Note  Feature order may change in relation to other output ports. Feature order per port is maintained.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases RasterPropertiesExtractor
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the RasterPropertyExtractor on the FME Community.
