PointCloudCombiner
PointCloudCombiner is often used to accumulate multiple point clouds into a single point cloud feature, but can also convert other geometries into point clouds and merge them.
Point and linear features will be converted point for point. Polygonal, donut, surface and solid features will be converted into a grid of points lying inside the area on the 3D plane represented by the area’s calculated normal. Any existing component values stored as measures or attributes can be preserved as components.
Rasters will be converted to point clouds as follows:
- The x and y components will be created from the columns and rows.
- The first selected numeric band will become the z component.
- The first selected bands with red/green/blue/gray interpretations will become the color_red/color_green/color_blue components.
- Additional selected bands will also be preserved. If the band has a name, the component name will be the band name. If the band has no name, the component name will be bandN, where N is the band index.
This transformer accepts all geometries. Area-based geometries will be converted to point clouds according to the spacing parameter.
A single point cloud feature.
Transformer
Use this parameter to organize point clouds into groups. Each group of point clouds will have its own output point cloud.
Note: How parallel processing works with FME: see About Parallel Processing for detailed information.
This parameter determines whether or not the transformer should perform the work across parallel processes. If it is enabled, a process will be launched for each group specified by the Group By parameter.
Parallel Processing Levels
For example, on a quad-core machine, minimal parallelism will result in two simultaneous FME processes. Extreme parallelism on an 8-core machine would result in 16 simultaneous processes.
You can experiment with this feature and view the information in the Windows Task Manager and the Workbench Log window.
No: This is the default behavior. Processing will only occur in this transformer once all input is present.
By Group: This transformer will process input groups in order. Changes on the value of the Group By parameter on the input stream will trigger batch processing on the currently accumulating group. This will improve overall speed if groups are large/complex, but could cause undesired behavior if input groups are not truly ordered.
Attributes
If this parameter is set to Yes, the attributes from the original features will be merged onto the output point cloud features.
If you specify a Count Attribute parameter (text string), an attribute with this name will be added to each output feature.
The attribute contains the number of features that were combined to create the point cloud feature.
Raster Parameters
This parameter specifies whether points should be created for nodata cells in rasters. When set to Yes, a point will be created for every cell in a raster, regardless of whether it is nodata. When set to No, points will not be created for nodata cells. A cell is considered to be nodata when, for each selected band, the value for that cell is equal to that band's nodata value. If any cell value is not equal to that band's nodata value, the cell will be considered data.
Vector Feature Interpolation
This parameter controls the spacing between points in ground coordinates that will be used to generate the representative point grid used for surfaces, solids, polygons, and donuts. You can either enter a number or extract the value from a selected attribute.
Measures to Preserve as Components
Specifies the measures on input vector geometries that should be preserved as components in the output point cloud. The type of the output component must also be specified.
Attributes to Preserve as Components
Specifies the attributes on input features that should be preserved as components in the output point cloud. The type of the output component must also be specified. Note that if the same component is specified as both a measure and attribute to preserve, the measure value will be preferred.
Transformer Categories
Search FME Knowledge Center
Tags Keywords: point "point cloud" cloud PointCloud coerce LiDAR sonar
