You are here: Filters and Joins > FeatureTypeFilter
FeatureTypeFilter
Routes input features to different output ports based on their original feature type. This transformer is especially useful when you have combined several input features for a particular operation (for example, a Clipper) but want to filter them afterwards in order to route them differently.
An output port is created for every connected feature type specified in the Feature Type Names parameter.
After connecting feature types to the Input port of the FeatureTypeFilter, open the transformer parameters and click the Update button at the bottom right. (You can also type names in the Feature Type Names field.) FME analyzes the workspace and determines the possible input feature types.
The Update button is enabled only if you are in the main tab and have an input feature type attached to the FeatureTypeFilter transformer. The Update button will then read the feature types on the connected reader and automatically populate the Feature Type Names list with those values.
Click Update again and FME creates the corresponding output ports for every new connection.
Note: Note that when you remove a connection and update the FeatureTypeFilter, the corresponding output port is removed, as well as any connections made from that port. To avoid this, proceed with caution.
You can dynamically create new destination feature types that connect to each output port created by the FeatureTypeFilter. In the Workbench canvas, right-click on the FeatureTypeFilter transformer and select Auto Connect. For more information, see Auto Connect to Destination Feature Types in the Workbench help.
Transformer Categories
Data Quality
Filters and Joins
Technical History
Associated FME function or factory: None
Search FME Knowledge Center
