PathSplitter
Decomposes a path feature into its component segments.
Each output feature will contain a copy of the source feature's attributes. Non-path input features will be output untouched.
If specified, each output feature is given an attribute containing the part's segment index within the original path feature.
The optional List Attribute is used to associate attributes with each segment of the path. If the feature has a list of attributes that are in parallel to the members of the aggregate, these can be decomposed onto the output features by specifying this parameter.
Transformer Categories
Search FME Knowledge Center
