HTMLExtractor
- Extracting content from a web page
The HTMLExtractor lets you define multiple queries to run against incoming HTML content, which can be provided either as an attribute or as a file. The queries are composed of an output attribute name, a CSS Selector which defines what type of tags to extract, and the choice of extracting whole tags, values, or HTML attributes.
You may either extract the first matching tag only, or keep multiple results as a list attribute.
The HTMLExtractor is better suited to HTML content than the XML transformers or regular expression searches, due to more lenient parsing and filters that can withstand minor changes to page content.
In this portion of a workspace, all of the links on a web page will be extracted and output as a list attribute.
An HTTPCaller retrieves the contents of a web page, using the GET method. The contents of the page are stored as HTML in the _response_body attribute.
In the HTMLExtractor, the same attribute is set as the HTML source, and a query is constructed to find all links (CSS Selector = a[href]), extract the only the link itself (Tag Part/HTML Attribute = href), and store that in a new attribute called links.
The Return Format is set to List Attribute, and so all matches will be included.
The output will look similar to this:
links{0} = ‘https://www.example.com/page1.html’
links{1} = ‘https://www.example.com/page2.html’
links{2} = ‘https://www.example.com/page3.html’
In this portion of a workspace, an HTTPCaller uses the GET method to retrieve the contents of a web page and store them in the attribute _response_body.
In the HTMLExtractor, a query is constructed to find the div tag with the id “article” (CSS Selector = div#article). The contents of that tag will be extracted (Tag Part/HTML Attribute = Value), and output to the new attribute articleText.
With the Return Format set to First Match, the contents of the first matching div tag encountered will be output as an ordinary (non-list) attribute.
- Standard CSS selectors are used to create queries. A list of them may be found here: CSS Selector Reference
Features with attributes containing the results of Extract Queries..
If an error occurs, the feature will be output via the <Rejected> port, with information about the error contained in the fme_rejection_code and fme_rejection_message attributes.
| HTML Input |
The type of source. Choices include:
| HTML Content | If HTML Input is set to Content, HTML content can either be specified directly in the HTML Content field, or set to the value of an attribute. |
| HTML File | If HTML Input is set to File, the path to an input HTML file can be specified. |
| Target Attribute | The name of the attribute that will hold the results of the query. |
| CSS Selector |
A CSS selector which specifies a tag or set of tags in the HTML document or content. A list of selectors can be found at: |
| Tag Part/HTML Attribute |
This parameter can be set to
Alternatively, an HTML attribute name (such as “href” or “alt”) can be entered. This will result in the attribute being extracted from the tag. |
Return Format |
If this is set to First Match, the target attributes will contain only the first element found that matches the query. If set to List Attributes, the target attributes will be lists, and will contain all results matching the query. |
Dialog Options
Enabled once you have clicked on a row in the Extract Queries. Choices include:
| A set of control characters is available in the Text Editor. | |
| Working with User Parameters | Create your own editable parameters. |
| History | Released: FME 2017.0 |
| Categories |
FME Knowledge Center
Search for all results about the HTMLExtractor on the FME Knowledge Center.
