You are here: Administrator's Guide > Securing FME Server > Connecting to Active Directory > Troubleshooting Active Directory Configurations
Tips before starting:
  • Start with the configuration in Recommended Configuration for Active Directory Connections.
  • Ensure that SECURITY_DEBUG=true is set in the fmeCommonConfig.txt. This configuration parameter is located under the 'Security Management' heading. With this debugging flag enabled, all interactions with Active Directory are logged.
  • Look in the fmeServer_* log files for messages with '(Active Directory)' or '(Single Sign-On)'. These files are located in <FMEServerDir>/Logs.
In this section
