FME Transformers: 2024.1
AreaBuilder
- Creating polygons from linear features
- Checking linear network topology
The AreaBuilder receives features with linear geometry (lines, paths, and polygons) and creates areas wherever the linework surrounds closed shapes.
Areas are output, as well as any geometry not used for area creation.
Attributes may be merged or dropped, or accumulated in a list attribute along with an optional direction attribute that records the orientation of the input features.
Output polygon boundaries may be either lines or paths that preserve the input segments. Where areas are contained within other areas, donuts may be created and the donut holes either output or discarded.
Stricter rules may be applied for successful area formation, including checking for continuous curve direction and internal edges (cycles).
Aggregate geometries are either deaggregated or rejected.
Z values are supported.
Preparing input features for the AreaBuilder
Input features must have clean topology or they will not be used and output as Incomplete. The AreaBuilder has snapping capability, but more pre-processing may be required.
Topology issues could be:
- Features not terminating at intersections
- Misaligned nodes
- Overshoots/undershoots
- Missing nodes at intersections
These transformers may be useful for pre-processing input features.
Use This For |
Description |
Snapping together misaligned nodes with more options than the AreaBuilder’s built-in snapping. |
Brings lines, segments, end points or vertex points of features together if they are within a certain distance of each other and (optionally) if they have attributes in common. |
Splitting intersecting features, adding new nodes where necessary. |
Computes intersections between all input features, breaking lines and polygons wherever an intersection occurs/ |
Chopping geometry into two-point lines, without adding any new nodes. |
Chops line, arc, path, or area features into smaller features based on number of vertices or approximate length. |
Adding length to undershoots (followed by an Intersector). |
Extends line, arc, or path features at both ends by a specified length. |
Building full topology on input features, which includes intersecting them. |
Computes topology on input point, line, and/or area features, and outputs significant nodes, edges, and faces with attributes describing topological relationships. |
In this example, we have a set a street features and want to build area polygons from them.
Note that the selected street is a single linear feature for its entire length.
The features are routed into an AreaBuilder.
In the parameters dialog, the default Polygon settings are used.
A list attribute named Streets is added which will contain the name of all surrounding streets for each output area, as well as the line segment orientation.
The output is not very successful, creating only a few areas.
An Intersector is added, with default settings used.
Note that the intersected output features are now split wherever they intersect another feature.
The intersected features are routed through another AreaBuilder (and then randomly colored for illustration purposes).
The output is successful this time. Note the list attribute, containing the street names and geometry orientation.
The Build Internal Edges (Advanced) parameter is for use with geometry that contains duplicate segments in opposing directions (cycles), as shown here.
Note that two features are selected, one on top of the other.
The second feature's coordinates are reversed. It's orientation is the opposite of the first feature.
When Build Internal Edges (Advanced) is No (the default), two areas are output and one of the duplicate segments is sent to the Incomplete output port.
If Create Donuts was enabled, the outer polygon would become a donut, and the inner its donut hole.
When Build Internal Edges (Advanced) is Yes, one area is created using all segments to form a continuous boundary with internal edges.
- As input features must be topologically correct for AreaBuilder to create polygons, it can be useful for checking topology.
- The AreaBuilder has some snapping capability, but the Snapper provides more snapping options.
Function |
Transformer Description |
Creating areas from topologically connected lines where they form closed shapes. |
Creates polygons from topologically correct linear features. |
Creating areas from individual linear features. |
Converts a linear feature to an area by connecting the end point to the start point. |
Combining touching or overlapping areas to create larger areas. |
Combines overlapping and/or adjacent areas into larger contiguous areas by removing shared and interior edges. |
Calculating areas. |
Cleaning up overlaps and gaps to create contiguous coverage. |
Generalizing areas. |
Converting donut areas to non-donut areas by connecting holes to the perimeter. |
Builds connections between donut holes with the outer boundary of a donut, resulting in a polygon-equivalent representation of the input donut. |
Converting areas within areas to donut holes. |
Cuts holes in area features where they fully enclose another area, creating donut polygons. |
Separating donut areas into their parts. |
Separates donut polygons into outer shell and hole polygons. |
Counting the number of holes in a donut area. |
Adds a new attribute whose value is the number of holes in the feature. If the feature is not a polygonal feature, 0 will be returned. |
Finding polygon overlaps and extracting them into new geometry. |
Performs an area-on-area overlay (intersection of polygons) so that all input areas are intersected against each other and resultant area features are created and output. The resultant areas can accumulate attribute from any overlapping polygons. |
Finding intersections between lines and polygons, splitting either where they intersect. |
Performs a line-on-area overlay, either splitting lines where they intersect area boundaries or subdividing areas where split by lines. Attributes may be shared between related lines and areas (spatial join). |
Identifying points that fall within polygons, and sharing attributes between them. |
Performs a point-in-polygon overlay. Points may receive containing area attributes, and areas may receive contained point attributes (spatial join). |
Features with topologically correct linear geometry.
Polygons created from the input features as specified in parameters.
Features that were not used to create areas.
INVALID_GEOMETRY_VERTICES
INVALID_GEOMETRY_DEGENERATE
Group By |
The default behavior is to use the entire set of input features as the group. This option allows you to select attributes that define which groups to form – each set of features that have the same value for all of these attributes will be processed as an independent group. No attributes other than the Group By ones will be carried across from the Input features to the output features. |
Complete Groups
Consider Node Elevation |
Select an option for handling z values, if they exist:
Connect Z Mode |
When Consider Node Elevation is No, select a method for handling z values if they exist. When viewed in 2D (ignoring Z), a path (which may define the border of a polygon) may appear to be closed as shown in the left figure below. This same path, when viewed in 3D, may appear to be open as shown in the right figure below.
Preserve Lines as Path Segments |
Select a method for creating area geometry:
Build Internal Edges (Advanced) |
Select an option for creating cycles in areas:
A cycle is a line segment that occurs twice in the same polygon's boundary, once in each direction. Note that areas with cycles may be considered invalid for other geometry processing or unsupported by some output formats. |
Check Curve Direction |
Select an option for evaluating the orientation of input features:
Aggregate Handling |
Choose how aggregate geometries are to be handled. Deaggregate: Decompose aggregates into their individual components. With this setting, the transformer might output more features than were given as inputs. Reject: Do not process aggregates and output them via the <Rejected> port. |
Create Donuts |
When enabled, areas fully contained within other areas produce donut polygons. The donut holes may be either kept or discarded. Donut holes that share edges are dissolved into larger holes.
When disabled, all areas are output without holes, and containing areas are not considered. Donuts and List Attributes: When list attributes are created on donut polygons, list items are included for all input features, including those that make up both the containing area and all holes. |
Snapping Type |
Select a method for the optional pre-processing of input features:
When two features are snapped together, the last feature (in order of processing) is modified to match the first. |
Snapping Tolerance |
When Snapping Type is End Point Snapping or Vertex Snapping, specify the maximum distance in ground units between points for them to be snapped together. |
Accumulation Mode |
Specify how attributes are accumulated on areas:
Generate List
When enabled:
Yes |
| Aliases | Polygonizer PolygonBuilder |
Search for all results about the AreaBuilder on the FME Community.
