FME Transformers: 2024.1
LineExtender
Extends line, arc, or path features at both ends by a specified length.
Preparing geometry for further processing
The LineExtender receives features with line, arc, or path geometry and extends them at both ends by a specified length in ground units.
Extension angle is the same as the orientation of the line segment leading to the extension point (the first or last vertex). Arc geometry extensions are also straight lines, placed tangent to the arc.
Optionally, the angle of a number of segments back from the point of extension can be averaged. If the Segments to Average value is larger than the number of segments available on the feature, the entire feature orientation is averaged. For arc geometry, the segments are produced by default arc stroking which can produce unpredictable angles.
Two-point linear extensions are output individually as Beginning and End.
A Stretched geometry is also produced. If extended from a line segment, the start and end vertices of the input feature are moved to the end position of the extensions. If extended from an arc, the end vertices remain intact.
If the stretched geometry includes an arc or path, it is output as a path.
Output features receive the same attributes as the input feature.
Z coordinates are supported.
Segments to Average |
Input |
Beginning and End |
Stretched |
| Default (1) |
2 |
Default (1) |
18 |
This transformer may be useful in combination with the Snapper and Intersector to perform simple data cleaning.
Creating and Modifying Linear Features
These transformers work with lines in a variety of ways.
Function |
Transformer Description |
Simple creation of lines from lines and/or points. |
Connects sequential point and/or line features to create line or area geometry. |
Combining adjoining lines into longer lines or complex paths, with more advanced geometry handling options than the LineBuilder. |
Connects line features that meet at common start or end points to create longer lines or paths. |
Combining arcs and lines into longer paths. |
Connects sequential line and/or arc features to create path geometry, preserving input segments. |
Converting linear features into areas. |
Converts a linear feature to an area by connecting the end point to the start point. |
Extending linear geometry. |
Extends line, arc, or path features at both ends by a specified length. |
Chopping features into smaller features, breaking them at their existing vertices. |
Chops line, arc, path, or area features into smaller features based on number of vertices or approximate length. |
Breaking a path into its component segments (lines and arcs). |
Splits path geometry into its component line and/or arc segments. |
Shortening linear geometry. |
Shortens linear geometry by cutting off the ends. |
Intersecting lines and areas. |
Performs a line-on-area overlay, either splitting lines where they intersect area boundaries or subdividing areas where split by lines. Attributes may be shared between related lines and areas (spatial join). |
Intersecting lines and lines. |
Performs a line-on-line overlay in which all input lines are intersected against each other and resultant line features are created and output. Intersection points are turned into point features that can contain the merged list of attributes of the original intersected lines. |
Finding where points lay on lines. |
Performs a point-on-line overlay. Each input line is split at its closest place to any point within the specified point tolerance, and attributes may be shared between related points and lines (spatial join). |
Features with line, arc, or path geometry to be extended.
A two-point line feature extending from the first vertex of the input feature according to parameter selections.
A two-point line feature extending from the last vertex of the input feature according to parameter selections.
Geometry composed of the input feature with start and end vertices moved to the extended positions (if extending from lines) or the input features with extensions added (if extending from arcs).
Features with geometry other than valid line, arc, or path geometry are output via this port.
INVALID_GEOMETRY_DEGENERATE
INVALID_PARAMETER
Extension Length |
Specify the length to extend the features, in ground units. |
(Optional) Specify a number of segments to be averaged when calculating the extension line orientation. If empty, one segment is used. |
Search for all results about the LineExtender on the FME Community.
