FME Transformers: 2024.1
PathBuilder
Connects sequential line and/or arc features to create path geometry, preserving input segments.
Combining geometry when input features are arcs
Combining geometry while preserving the input segments
The PathBuilder receives features with line or arc geometry and connects them in the order received.
Gaps between input features are connected as follows:
Line to line or arc: the first line is extended to to start point of the next feature.
Arc to line: the line is extended from its start point to the end point of the arc.
Arc to arc: a two-point line connects the end of the first arc to the start of the second arc.
Z coordinates are supported. Features with matching x and y coordinates but differing z values at their connection points are handled according to the Connect Z Mode parameter.
Attributes may be collected as a list attribute, preserving attribute values for every segment which can later be reconstructed as individual geometries with a PathSplitter.
Note that path geometry is not supported in all output formats. See also: Line , Arc, and Path geometry.
In this example, a transit line is represented by a number of line segments, each approximately 1,000 meters in length, with varying numbers of coordinates per segment.
We want to combine these into a single geometry but keep the segment information intact.
The features are routed into a PathBuilder.
In the parameters dialog, the default settings are kept.
One feature is output with Path geometry. Note that the original segments are intact within the path and could be recreated using a PathSplitter.
If the features are processed using a LineBuilder, the segments are merged into a single line containing all coordinates of the input features. The input segmentation is lost.
If the individual segments of a longer line have varying attributes - fluctuating speed limits on a highway, for example - those attribute values can be preserved as a list attribute on path geometry and later retrieved when the path is split back into its component segments.
Creating a path and preserving attributes
In this example, we have a set of short lines that make up a bike path. The attribute values can vary from segment to segment.
We want to treat the bike path as a single piece of geometry, but retain the original segment details - both geometry and attribution.
The lines are routed into a PathBuilder.
In the parameters dialog, Generate List is enabled, the list is named SegmentAttributes, and All Attributes are added to list.
The output path has a SegmentAttributes list with 11 list items, and its geometry is a Path with 11 segments.
Note the difference between the attribute values on list items 9 and 10.
Splitting a path and recovering attributes
In this example, we want to recover the original geometry and attribution from the path with a list attribute created in the example above.
Note the path geometry with 11 segments and the SegmentAttributes list with 11 items.
The path is routed into a PathSplitter.
In the parameters dialog, Segment List is set to the list attribute SegmentAttributes.
The output features receive attribute values according to path segment and list item pairs.
The Sorter may be useful for ordering features before using the PathBuilder.
It is possible to create self-intersecting paths with this transformer, which will not be rejected.
As the PathBuilder fills in gaps between features, it can produce unexpected results if the input features are not sorted correctly. To combine adjoining lines (without creating new geometry to connect gaps), use a LineCombiner (and ArcStroker, if arcs are present).
Aggregate geometry also treats multiple geometries as a single unit, but path geometry ensures that the components are contiguous and connected.
The PathSplitter will undo PathBuilder output.
Creating and Modifying Linear Features
These transformers work with lines in a variety of ways.
Function |
Transformer Description |
Simple creation of lines from lines and/or points. |
Connects sequential point and/or line features to create line or area geometry. |
Combining adjoining lines into longer lines or complex paths, with more advanced geometry handling options than the LineBuilder. |
Connects line features that meet at common start or end points to create longer lines or paths. |
Combining arcs and lines into longer paths. |
Connects sequential line and/or arc features to create path geometry, preserving input segments. |
Converting linear features into areas. |
Converts a linear feature to an area by connecting the end point to the start point. |
Extending linear geometry. |
Extends line, arc, or path features at both ends by a specified length. |
Chopping features into smaller features, breaking them at their existing vertices. |
Chops line, arc, path, or area features into smaller features based on number of vertices or approximate length. |
Breaking a path into its component segments (lines and arcs). |
Splits path geometry into its component line and/or arc segments. |
Shortening linear geometry. |
Shortens linear geometry by cutting off the ends. |
Intersecting lines and areas. |
Performs a line-on-area overlay, either splitting lines where they intersect area boundaries or subdividing areas where split by lines. Attributes may be shared between related lines and areas (spatial join). |
Intersecting lines and lines. |
Performs a line-on-line overlay in which all input lines are intersected against each other and resultant line features are created and output. Intersection points are turned into point features that can contain the merged list of attributes of the original intersected lines. |
Finding where points lay on lines. |
Performs a point-on-line overlay. Each input line is split at its closest place to any point within the specified point tolerance, and attributes may be shared between related points and lines (spatial join). |
This transformer accepts features with line, arc, or path geometry. Where paths are input, they remain intact and other geometry is prepended or appended according to order of input.
Input segments combined into path features are output here.
Features with geometry other than valid line, arc, or path geometry are output via this port.
Group By |
The default behavior is to use the entire set of input features as the group. This option allows you to select attributes that define which groups to form – each set of features that have the same value for all of these attributes will be processed as an independent group. The feature being created is output whenever a Group By value changes. When this happens, the feature with the differing attribute is not added to the current output feature; instead, it begins the next feature to be output. |
Complete Groups |
Connect Z Mode |
Where connection points have matching x and y coordinates but differing z values, select a method for handling z. When viewed in 2D (ignoring Z), a path (which may define the border of a polygon) may appear to be closed as shown in the left figure below. This same path, when viewed in 3D, may appear to be open as shown in the right figure below.
Aggregate Handling |
Select how aggregate geometries are to be handled:
Generate List |
When enabled:
Yes |
Search for all results about the PathBuilder on the FME Community.
