FME Transformers: 2024.1
PointOnLineOverlayer
Performs a point-on-line overlay. Each input line is split at its closest place to any point within the specified point tolerance, and attributes may be shared between related points and lines (spatial join).
- Splitting lines where they overlay points
- Identifying lines that intersect with a point
- Identifying points that fall on a line
The PointOnLineOverlayer compares points and lines, splitting the lines where a point falls on (or within a specified distance of) the lines. Each resulting new line may receive the attributes of the points that matched the original line, and points may receive attributes from the lines (a spatial join). Features (points and lines) also receive a count of the number of matches encountered.
Aggregates can either be deaggregated before processing or rejected. Intersections between linear features are not computed.
In this example, we perform an overlay of rapid transit stations points on rapid transit lines. The source data, as seen here, contains three individual transit routes, each one a single line feature.
The station points are close to the lines, but not right on them - generally within a meter.
The stations are connected to the Point input port, and the routes are connected to the Line input port.
In the parameters dialog, we enter a tolerance of “5” - meaning 5 meters, as these datasets are in a UTM projection, with ground units in meters. We also choose to merge attributes.
The transit lines are split where they encounter a station within the specified tolerance, as shown here by randomly coloring the output line features. Attributes are shared between the points and lines, as in these point attributes for Renfrew Station, which now has a new attribute indicating that it overlaid the Millennium Line.
Output Lines receive attributes from all of the points that the original unchopped line encountered - see Usage Notes for more detail.
- Where point geometries are expected, Point Cloud geometries are not supported.
- Chopped Lines output via the Line output port receive the attributes of all points that matched the original input line (if a list is enabled). All points that the original line encountered are included - not only the endpoints of the new line segment.
To obtain attributes from points matching only the ends of the new line features, use a second transformer (consider another PointOnLineOverlayer, or a NeighborFinder).
Z Values and Measures
If the input Line features have measures and/or 3D coordinates, measures and elevations (z values) are interpolated and assigned to points according to the selections made in the Attribute Accumulation parameters.
If Attribute Accumulation Mode is set to Drop Incoming Attributes, the measures and z values will be ignored. If it is set to Merge, Prefix, or Replace with Single Incoming, the appropriate values will be calculated and assigned to the points. If a z value is added to a 2D point, it will become 3D.
Transformer |
Can Merge Attributes |
Alters Geometry |
Counts Related Features |
Creates List |
Supported Types* |
Recommended For |
* Note that Curve includes Lines, Arcs, and Paths. Area includes Polygons, Donuts, and Ellipses.
When there are multiple ways to configure a workspace to reach the same goal, it is often best to choose the transformer most specifically suited to your task.
Point features against which the lines will be compared.
Line features against which the points will be compared.
Point features, with attributes added according to transformer parameter configuration. Geometry is unmodified, unless z-values have been extracted from lines.
Line features which have been split at the location closest to matching points, with attributes added according to transformer parameter configuration.
Features with invalid geometries will be rejected and output via this port.
INVALID_POINT_GEOMETRY_TYPE
INVALID_LINE_GEOMETRY_TYPE
INVALID_LINE_GEOMETRY_VERTICES
INVALID_GEOMETRY_DEGENERATE
Group By |
The default behavior is to use the entire set of features as the group. This option allows you to select attributes that define which groups to form. |
Complete Groups |
Point Tolerance |
The Point Tolerance value is compared to the distance from the lines to the points, and the lines will be segmented if the distance is less than or equal to the Point Tolerance value. When such a match occurs, the attributes of the segmented lines are merged with the points and the attributes of the points are merged with the lines. |
Aggregate Handling |
Choose how aggregate geometries are to be handled. Deaggregate: Decompose aggregates into their individual components. Reject: Do not process aggregates and output them via the <Rejected> port. |
Merge Measures
If Yes, any measures that exist on a line will be added to matching points. Measure values are determined according to the Treat Measures As parameter. If both point and line have measures of the same name, the point's values will be overwritten by the line's values. If No, no measures will be copied, and any existing measures (on points or lines) will be output unchanged. |
Treat Measures As |
This parameter determines how measures are computed:
Continuous: The new measure value will be calculated, interpolating based on the nearest measures. Discrete: The new measure value will be copied from the nearest measure. |
If attributes on the incoming and original feature share the same name, but are not geometry attributes that start with fme_, then they are deemed conflicted.
If measures on the point and line share the same name, then they are deemed conflicted.
The resolution of conflicted measures on points occurs in the same manner as the resolution of conflicted attributes on features. It is resolved according to the Accumulation Mode and Conflict Resolution values.
Merge Attributes
Accumulation Mode |
Merge Incoming: The original feature will retain all of its own un-conflicted attributes, and will additionally acquire any un-conflicted attributes that the incoming feature has. This mode will handle conflicted attributes based on the Conflict Resolution parameter. Prefix Incoming: The original feature will retain all of its own attributes. In addition, the original will acquire attributes reflecting the incoming feature’s attributes, with the name prefixed with the Prefix parameter. Replace with Single Incoming: The original feature will have all of its attributes removed, except geometry attributes that start with fme_. Then, all of the attributes from one (arbitrary) incoming feature will be placed onto the original. |
Conflict Resolution |
Use Original: If a conflict occurs, the original values will be maintained. Use Incoming: If a conflict occurs, the values of the incoming will be transferred onto the original. |
Prefix |
If the Accumulation Mode parameter is set to Prefix Incoming, this value will prefix attributes and measures that are being added to the original feature from the incoming feature. |
Generate List on Output ‘Point’
When enabled, adds a list attribute to the Point output features, and the attributes of each line matching an output point are added to that point's list.
‘Point’ List Name |
Enter a name for the list attribute. Note List attributes are not accessible from the output schema in FME Workbench unless they are first processed using a transformer that operates on them, such as ListExploder or ListConcatenator. Alternatively, AttributeExposer can be used.
Add To 'Point' List |
All Attributes: All attributes will be added to the output Point features. Selected Attributes: Enables the Selected Attributes parameter, where specific attributes may be chosen for inclusion. |
Selected Attributes |
Enabled when Add To 'Point' List is set to Selected Attributes. Specify the attributes you wish to be included. |
Generate List on Output ‘Line’
When enabled, adds a list attribute to the Line output features, and the attributes of each point matching an original input line are added to each output line created from it.
‘Line’ List Name |
Add To 'Line' List |
All Attributes: All attributes will be added to the output Line features. Selected Attributes: Enables the Selected Attributes parameter, where specific attributes may be chosen for inclusion. |
Enabled when Add To 'Line' List is set to Selected Attributes. Specify the attributes you wish to be included. |
Overlap Count |
The Overlap Count Attribute added to output linear features holds the number of point features that were near to it. The Overlap Count Attribute added to output point features holds the number of linear features that the point was near to. |
Yes |
| Dependencies | |
Search for all results about the PointOnLineOverlayer on the FME Community.
