FME Transformers: 2024.1
PathSplitter
Splits path geometry into its component line and/or arc segments.
Decomposing PathBuilder or CurveFitter output
Preparing geometry for formats that do not support paths
The output features may have either line or arc geometry, and retain the input path’s attributes unless a Segment List list attribute is provided, as shown in the Paths and List Attributes example below.
Each segment’s number within the path can be added as an attribute.
Features with non-path geometry are passed through unchanged.
Note that path geometry is not supported in all output formats. See also: Line , Arc, and Path geometry.
In this example, we have a path feature representing a transit line. The path is made up of numerous arc and short line segments.
We want to split this path into its component parts.
The feature is routed into a PathSplitter.
In the parameters dialog, the default settings are kept. Note that the Segment List parameter is not available, as the input feature has no list attribute on it.
One feature is output for each path segment, with a new attribute containing the segment number.
If the individual segments of a longer line have varying attributes - fluctuating speed limits on a highway, for example - those attribute values can be preserved as a list attribute on path geometry and later retrieved when the path is split back into its component segments.
Creating a path and preserving attributes
In this example, we have a set of short lines that make up a bike path. The attribute values can vary from segment to segment.
We want to treat the bike path as a single piece of geometry, but retain the original segment details - both geometry and attribution.
The lines are routed into a PathBuilder.
In the parameters dialog, Generate List is enabled, the list is named SegmentAttributes, and All Attributes are added to list.
The output path has a SegmentAttributes list with 11 list items, and its geometry is a Path with 11 segments.
Note the difference between the attribute values on list items 9 and 10.
Splitting a path and recovering attributes
In this example, we want to recover the original geometry and attribution from the path with a list attribute created in the example above.
Note the path geometry with 11 segments and the SegmentAttributes list with 11 items.
The path is routed into a PathSplitter.
In the parameters dialog, Segment List is set to the list attribute SegmentAttributes.
The output features receive attribute values according to path segment and list item pairs.
The PathBuilder, Curvefitter, and LineExtender can output path geometries.
Aggregate geometry also treats multiple geometries as a single unit, but path geometry ensures that the components are contiguous and connected.
This transformer and the ArcStroker may be useful in preparing geometry for output formats with limited geometry support.
The GeometryCoercer, DonutHoleExtractor, and Deaggregator may be useful in preparing geometry for the PathSplitter.
Creating and Modifying Linear Features
These transformers work with lines in a variety of ways.
Function |
Transformer Description |
Simple creation of lines from lines and/or points. |
Connects sequential point and/or line features to create line or area geometry. |
Combining adjoining lines into longer lines or complex paths, with more advanced geometry handling options than the LineBuilder. |
Connects line features that meet at common start or end points to create longer lines or paths. |
Combining arcs and lines into longer paths. |
Connects sequential line and/or arc features to create path geometry, preserving input segments. |
Converting linear features into areas. |
Converts a linear feature to an area by connecting the end point to the start point. |
Extending linear geometry. |
Extends line, arc, or path features at both ends by a specified length. |
Chopping features into smaller features, breaking them at their existing vertices. |
Chops line, arc, path, or area features into smaller features based on number of vertices or approximate length. |
Breaking a path into its component segments (lines and arcs). |
Splits path geometry into its component line and/or arc segments. |
Shortening linear geometry. |
Shortens linear geometry by cutting off the ends. |
Intersecting lines and areas. |
Performs a line-on-area overlay, either splitting lines where they intersect area boundaries or subdividing areas where split by lines. Attributes may be shared between related lines and areas (spatial join). |
Intersecting lines and lines. |
Performs a line-on-line overlay in which all input lines are intersected against each other and resultant line features are created and output. Intersection points are turned into point features that can contain the merged list of attributes of the original intersected lines. |
Finding where points lay on lines. |
Performs a point-on-line overlay. Each input line is split at its closest place to any point within the specified point tolerance, and attributes may be shared between related points and lines (spatial join). |
Features with path geometry and (optionally) list attributes.
One feature for each segment of the input path.
Input features with non-path geometry are output here unchanged.
Segment Number |
Name the attribute to contain the segment number of the output feature. |
Segment List |
If the input has a list attribute containing attribute values corresponding to the path segments, it may be specified here. List item attributes and values are applied to the output features. See the Paths and List Attributes example above. |
Search for all results about the PathSplitter on the FME Community.
