FME Transformers: 2024.1
LineCloser
Creating areas from unclosed linear features
The LineCloser receives linear features and connects their end points to their start points, creating closed polygons. An additional vertex is added at the position of the start point.
Z coordinates are supported. Where the first and last points of the input feature have the same x and y coordinates but differing z values, the Connect Z Mode parameter determines how the points are handled.
No checking is performed on the output geometry, and self-intersecting polygons can be created.
Non-linear features are passed through unchanged.
In this example, we have a series of GPS points along a route surrounding an area. We want to build a polygon of the area.
The points are ordered by their PointID attribute. We need to connect the points to create linear geometry.
The points are routed into a LineBuilder.
The output geometry connects the input points, but has not created a closed polygon.
The last GPS point is not in the same position as the first.
The line is routed into a LineCloser.
An additional point is added to the line, in the same position as the first, and the area is closed. Note the Coordinates count has increased by 1.
The AreaBuilder can also close linear geometry into areas, but moves the end vertex rather than adding an additional vertex to close.
Use the GeometryValidator to check for self-intersecting geometry after using the LineCloser.
Creating and Modifying Linear Features
These transformers work with lines in a variety of ways.
Function |
Transformer Description |
Simple creation of lines from lines and/or points. |
Connects sequential point and/or line features to create line or area geometry. |
Combining adjoining lines into longer lines or complex paths, with more advanced geometry handling options than the LineBuilder. |
Connects line features that meet at common start or end points to create longer lines or paths. |
Combining arcs and lines into longer paths. |
Connects sequential line and/or arc features to create path geometry, preserving input segments. |
Converting linear features into areas. |
Converts a linear feature to an area by connecting the end point to the start point. |
Extending linear geometry. |
Extends line, arc, or path features at both ends by a specified length. |
Chopping features into smaller features, breaking them at their existing vertices. |
Chops line, arc, path, or area features into smaller features based on number of vertices or approximate length. |
Breaking a path into its component segments (lines and arcs). |
Splits path geometry into its component line and/or arc segments. |
Shortening linear geometry. |
Shortens linear geometry by cutting off the ends. |
Intersecting lines and areas. |
Performs a line-on-area overlay, either splitting lines where they intersect area boundaries or subdividing areas where split by lines. Attributes may be shared between related lines and areas (spatial join). |
Intersecting lines and lines. |
Performs a line-on-line overlay in which all input lines are intersected against each other and resultant line features are created and output. Intersection points are turned into point features that can contain the merged list of attributes of the original intersected lines. |
Finding where points lay on lines. |
Performs a point-on-line overlay. Each input line is split at its closest place to any point within the specified point tolerance, and attributes may be shared between related points and lines (spatial join). |
Features with linear geometry.
Polygons created by closing linear features, as well as untouched input features.
Connect Z Mode |
Where start and end points have matching x and y coordinates but differing z values, select a method for handling z. When viewed in 2D (ignoring Z), a path (which may define the border of a polygon) may appear to be closed as shown in the left figure below. This same path, when viewed in 3D, may appear to be open as shown in the right figure below.
Search for all results about the LineCloser on the FME Community.
