FME Transformers: 2024.1
LineBuilder
Connects sequential point and/or line features to create line or area geometry.
- Connecting points to form a line
- Connecting multiple lines into longer, continuous lines
The LineBuilder receives features with point and/or line geometry, and connects them in the order received, producing line or area geometry.
Both the order in which the features enter the transformer and the orientation of any line geometry received are honored. Gaps between line features are connected, and duplicate points may be either processed or ignored.
Z values are supported. If some input features have z values and others do not, those without are assigned a z value of zero (0). Features with matching x and y coordinates but differing z values are not considered duplicates.
If the output feature is closed (the first and last x and y coordinates are the same), an area is output whether or not the z values match.
Features may be grouped by attribute values to produce multiple outputs.
Attributes may be merged, dropped, or collected as List Attributes.
In this example, we have a set of point features captured by GPS along a route. We want to create a line from these sequential points.
The features are routed into a LineBuilder.
In the parameters dialog, the default settings are used.
A single line feature is output, connecting all of the input points in the order they were received.
- The Sorter may be useful for ordering features before using the LineBuilder.
- As the LineBuilder fills in gaps between features, it can produce unexpected results if the input features are not sorted correctly. To combine adjoining lines (without creating new geometry to connect gaps), use a LineCombiner.
- The CoordinateSwapper may be useful in specific cases.
Creating and Modifying Linear Features
These transformers work with lines in a variety of ways.
Function |
Transformer Description |
Simple creation of lines from lines and/or points. |
Connects sequential point and/or line features to create line or area geometry. |
Combining adjoining lines into longer lines or complex paths, with more advanced geometry handling options than the LineBuilder. |
Connects line features that meet at common start or end points to create longer lines or paths. |
Combining arcs and lines into longer paths. |
Connects sequential line and/or arc features to create path geometry, preserving input segments. |
Converting linear features into areas. |
Converts a linear feature to an area by connecting the end point to the start point. |
Extending linear geometry. |
Extends line, arc, or path features at both ends by a specified length. |
Chopping features into smaller features, breaking them at their existing vertices. |
Chops line, arc, path, or area features into smaller features based on number of vertices or approximate length. |
Breaking a path into its component segments (lines and arcs). |
Splits path geometry into its component line and/or arc segments. |
Shortening linear geometry. |
Shortens linear geometry by cutting off the ends. |
Intersecting lines and areas. |
Performs a line-on-area overlay, either splitting lines where they intersect area boundaries or subdividing areas where split by lines. Attributes may be shared between related lines and areas (spatial join). |
Intersecting lines and lines. |
Performs a line-on-line overlay in which all input lines are intersected against each other and resultant line features are created and output. Intersection points are turned into point features that can contain the merged list of attributes of the original intersected lines. |
Finding where points lay on lines. |
Performs a point-on-line overlay. Each input line is split at its closest place to any point within the specified point tolerance, and attributes may be shared between related points and lines (spatial join). |
If the resulting feature is a single point, it will be output through this port.
If the resulting feature does not begin and end at the same point, it is output through this port.
If the resulting feature forms a ring (begins and ends at the same point), it is output through this port.
Any features that are not points or lines are output through this port.
Group By |
The default behavior is to use the entire set of input features as the group. This option allows you to select attributes that define which groups to form – each set of features that have the same value for all of these attributes will be processed as an independent group. If only one point feature was received with a given value for the Group By value, it will be output as a Point. If the feature output forms a ring (begins and ends at the same point), it is output as a Polygon. Anything else is output as a Line. |
Complete Groups |
Remove Duplicate Points |
If Yes, duplicate coordinates from input features are removed. That is, if two point features, both at (0,0,0) are input, one point at (0,0,0) is output. If No, duplicate coordinates from input features are not removed. That is, if two point features at (0,0,0) are input, a line is output with two coordinates, both at (0,0,0). |
Accumulation Mode |
Specify how attributes are accumulated on combined lines:
Generate List
When enabled:
Search for all results about the LineBuilder on the FME Community.
Keywords: "point joiner" "line creator" PointConnector
