FME Transformers: 2024.1
AreaGapAndOverlapCleaner
Repairs area topologies by resolving gaps and overlaps between adjacent areas.
- Cleaning topology errors in a polygon coverage to create a single, contiguous surface.
The AreaGapAndOverlapCleaner receives features with valid area geometry and cleans up shared boundaries by dissolving overlaps and filling in gaps between polygons.
Input aggregate geometry may be either deaggregated or rejected.
Z values and measures are supported.
Repairing Overlaps and Gaps
Overlaps and gaps are processed slightly differently.
Both use the Tolerance and Repair Method parameters to determine how they are resolved. Gaps are further handled according to the Fill All Gaps parameter.
Overlaps are all processed, all the time. If the overlap is within the Tolerance distance, the repair is done automatically. If the overlap is greater than the tolerance, the Repair Method choice is used.
Gaps within the Tolerance distance are repaired automatically. If Fill All Gaps is Yes, gaps greater than the tolerance are repaired according to the Repair Method choice. If Fill All Gaps is No, they are not repaired.
Fill All Gaps |
Within Tolerance |
Greater Than Tolerance |
Overlaps |
Automatic |
Per Repair Method |
Gaps |
Automatic |
Untouched |
Gaps |
Yes |
Automatic |
Per Repair Method |
Tolerance
Tolerance is a distance in the ground units of the features’ coordinate system. The choices are to enter a value or choose Automatic.
For most transformers with a Tolerance parameter, Automatic is recommended, but it is frequently not the correct choice here. Automatic will calculate a value that accounts for minute differences introduced by binary limitations, rounding errors, and the like (See Geometry Concepts > Tolerance). The calculated value is written to the log file.
Tolerance is always greater than zero.
Tolerance > Automatic does not consider the size of gaps and overlaps present in the data. For many use cases, this value is too small and an explicit value should be entered. The value should be guided by the nature of the input geometry (size of gaps and polygons) and whether you want the repairs to be automatically handled or determined by a specific Repair Method.
Repair Method
Gaps and overlaps greater than the Tolerance value are repaired according to the Repair Method:
- Longest Boundary: Gaps and overlaps are allocated to the area with the longest boundary.
- Random: Gaps and overlaps are allocated to areas selected at random.
- Priority (Edge Preserving): Gaps and overlaps are allocated according to a numeric priority attribute:
- Overlaps go to the higher priority area.
- Gaps go to the lower priority area.
- The boundary of the higher priority area is preserved.
- Priority (Area Enlarging): Gaps and overlaps are allocated according to a numeric priority attribute:
- Both overlaps and gaps go to the higher priority area.
- The higher priority area may be enlarged.
When using Priority methods, zero (0) is the highest priority. If there is a conflict where more than one area has the same priority, one is selected arbitrarily.
In this example, we have a set of parcel features, separated in places by roadways and lanes.
On close examination, the data is not clean and needs to be repaired. There are random overlaps and gaps.
Note that this laneway is approximately 6 meters wide. It a valid gap that should be preserved.
Tolerance: Too Large
The features are routed into an AreaGapAndOverlapCleaner.
In the parameters dialog, Tolerance is set to 20 (meters, in ground units). Fill All Gaps is No, so that only gaps within the tolerance will be repaired.
The results are not good. As the tolerance is wider than the valid gap, the laneway has been filled in, crookedly.
When tolerance is too large, unpredictable results occur, including spikes, deformed shapes, and valid areas filled in.
Tolerance: Just Right
In the parameters dialog, Tolerance is set to 2.5 - a value that is less than the width of valid gaps, but large enough to capture the errors.
Gaps and overlaps are repaired.
Valid gaps are preserved and feature shapes are intact.
In this example, we have two datasets with area geometry - zoning polygons and two-line rivers. Note that the selected zone polygon has a PRIORITY value of 1.
We want contiguous coverage, with the zones meeting the river’s edge.
On closer inspection, the two datasets do not meet smoothly. There are gaps and overlaps. Note that the river polygon has a PRIORITY value of 0.
We want to clean up the data and preserve the shape of the river polygons - not adjust the river to the shape of the zones.
Both datasets are routed into AttributeCreators to add their PRIORITY value, and then on to an AreaGapAndOverlapCleaner.
In the parameters dialog, Tolerance is set to Automatic. This will compute an extremely small tolerance number (see Tolerance above).
All of the visible errors will be much larger than this tolerance, and so will have the Outside Tolerance Parameters applied - Fill All Gaps, Repair Method, and Priority Attribute.
Repair Method is set to Priority (Edge Preserving), with the PRIORITY attribute chosen.
Zero (0) is the highest priority.
Overlaps are absorbed into the river, and gaps are added on to the zones. The shape of the river is preserved, and the coverage is contiguous.
- When unexpected results are output, it can often be corrected by adjusting the Tolerance value.
- To repair only overlaps (not gaps), consider using a Dissolver.
- Invalid area geometry such as self-intersecting or degenerate polygons will not be rejected, but will not be repaired properly.
- Donut holes are gaps, and may be processed accordingly.
Function |
Transformer Description |
Creating areas from topologically connected lines where they form closed shapes. |
Creates polygons from topologically correct linear features. |
Creating areas from individual linear features. |
Converts a linear feature to an area by connecting the end point to the start point. |
Combining touching or overlapping areas to create larger areas. |
Combines overlapping and/or adjacent areas into larger contiguous areas by removing shared and interior edges. |
Calculating areas. |
Cleaning up overlaps and gaps to create contiguous coverage. |
Generalizing areas. |
Converting donut areas to non-donut areas by connecting holes to the perimeter. |
Builds connections between donut holes with the outer boundary of a donut, resulting in a polygon-equivalent representation of the input donut. |
Converting areas within areas to donut holes. |
Cuts holes in area features where they fully enclose another area, creating donut polygons. |
Separating donut areas into their parts. |
Separates donut polygons into outer shell and hole polygons. |
Counting the number of holes in a donut area. |
Adds a new attribute whose value is the number of holes in the feature. If the feature is not a polygonal feature, 0 will be returned. |
Finding polygon overlaps and extracting them into new geometry. |
Performs an area-on-area overlay (intersection of polygons) so that all input areas are intersected against each other and resultant area features are created and output. The resultant areas can accumulate attribute from any overlapping polygons. |
Finding intersections between lines and polygons, splitting either where they intersect. |
Performs a line-on-area overlay, either splitting lines where they intersect area boundaries or subdividing areas where split by lines. Attributes may be shared between related lines and areas (spatial join). |
Identifying points that fall within polygons, and sharing attributes between them. |
Performs a point-in-polygon overlay. Points may receive containing area attributes, and areas may receive contained point attributes (spatial join). |
Features with area geometry.
Features with gaps and overlaps resolved are output here, including untouched input features.
Geometries that collapsed within tolerance are output here, as well as any features left with null geometry after overlap resolution.
Features with invalid geometries will be rejected and output via this port.
When Repair Method is Priority (Edge Preserving) or Priority (Area Enlarging), features with invalid priority attributes will also be rejected via this port.
INVALID_PARAMETER_PRIORITY_ATTRIBUTE
Group By |
The default behavior is to use the entire set of features as the group. This option allows you to select attributes that define which groups to form. |
Complete Groups |
Tolerance |
Specify the maximum distance (in ground units) between geometries in 2D for features to be automatically repaired. If Automatic, tolerance is calculated based on the input features and addresses only extremely small variations. The value is written to the log file. See Tolerance above, as well as Geometry Concepts > Tolerance. |
Aggregate Handling |
Choose how aggregate geometries are to be handled. Deaggregate: Decompose aggregates into their individual components. With this setting, the transformer might output more features than were given as inputs. Reject: Do not process aggregates and output them via the <Rejected> port. |
Connect Z Mode |
If applicable, select a method for handling z values. When viewed in 2D (ignoring Z), a path (which may define the border of a polygon) may appear to be closed as shown in the left figure below. This same path, when viewed in 3D, may appear to be open as shown in the right figure below.
Measures/Z Conflict Value |
Select a method for handling geometries that have a measure, but are missing at least one value, or that have z values but are missing at least one value.
Treat Measures as |
When using the Compute mode to compute missing measure values, measures can be considered Continuous, and linearly interpolated from their neighbors, or they can be Discrete, and taken exactly from the nearest neighbor. |
Fill All Gaps |
Select an option for gaps repair:
Repair Method |
Select a method for repairing gaps and overlaps that are larger than the Tolerance value.
Priority Attribute |
When Repair Method is either Priority (Edge Preserving) or Priority (Area Englarging), specify the attribute containing the priority value. Priority values are positive integers. Zero (0) denotes the highest priority. |
Yes |
| Dependencies | |
| Aliases | SliverRemover |
Search for all results about the AreaGapAndOverlapCleaner on the FME Community.
