FME Transformers: 2024.1
DonutBridgeBuilder
Builds connections between donut holes with the outer boundary of a donut, resulting in a polygon-equivalent representation of the input donut.
A single, connected path visits the boundary and each donut hole exactly once and guaranteed to not cross over itself completely if the input feature is properly oriented. This action is performed on all donuts contained in an input feature.
The transformer outputs unmodified features at the Invalid port when a feature contains a donut with faulty topology (such as a hole lying outside of an outer boundary).
Example
The generated polygon boundary will have shared, overlapping boundary segments where the rings connect to each other.
Another example shows a county in Washington, USA, consisting of several islands. The islands are cut from an expanded bounding box, and the workspace converts the remaining donut into a polygon:
Search for all results about the DonutBridgeBuilder on the FME Community.
