You are here: Reference Manual > FME Server Services > Transformation Services > Job Submitter Service > Web Application Properties
Properties for the Job Submitter Service are defined in the propertiesFile.properties configuration file at this location:
<WebAppDir>/fmejobsubmitter/WEB-INF/
conf/propertiesFile.properties
Job Submitter Service Properties File Content
# Job Submitter Servlet configuration file
# This file details the installation parameters of the Job Submitter Servlet.
# SERVER_NAME - The computer where the Transformation Manager is running. Can be specified
# as a network name (ie: "ATHENA") or an IP. The default value is
# "localhost".
SERVER_NAME=localhost
# SERVER_PORT - The port on which the Transformation Manager is running on the remote
# machine. This is an integer between 1025 and 65535.
# The default value is the default Transformation Manager listening port,
# which is 7071.
SERVER_PORT=7071
# SCHEDULER_PORT - The port on which the Scheduler Manager is listening.
SCHEDULER_PORT=7073
# CONNECTION_POOL_EXPIRY - The length of time in seconds in which an FME Server connection remains idle
# before expiring from the connection pool.
# If a value of less than or equal to zero is specified, then there is no
# connection pooling.
CONNECTION_POOL_EXPIRY=300
# RESOURCE_PATH - This is the path to the textual resources of the log.
# This file stores all the messages that will appear in the
# log as well as their code.
RESOURCE_PATH=C:/ProgramData/Safe Software/FME Server//localization
# MIN_TIME_BETWEEN_REQS - This is the minimal amount of time that a client
# must wait before sending another request. If a
# request is sent before that interval, it will be
# ignored. The time is specified in milliseconds.
MIN_TIME_BETWEEN_REQS=1000
# LOG_CONFIG_PATH - The folder path that contains the log file configuration.
LOG_CONFIG_PATH=C:/Program Files/FMEServer/Utilities/config
# LOG_FILE_NAME - The file name that the log files will have in common.
LOG_FILE_NAME=jobsubmitterservice.log
#ATTACH_TRANSFORMATION_LOG - A boolean value that determines if transformation
# log needs to be attached to notification email
ATTACH_TRANSFORMATION_LOG=false
#DEFAULT_RESPONSE_FORMAT - The default response format
DEFAULT_RESPONSE_FORMAT=HTML
#DEFAULT_USER_ID - The default user ID to log in FME Server
DEFAULT_USER_ID=guest
#DEFAULT_PASSWORD - The default password for default user ID
DEFAULT_PASSWORD=guest
#SECURE_CLIENT_ADDRESS - A boolean value that determines if token authentication includes the client
# address. Set it to true if enhanced security is required. The default value
# is false.
SECURE_CLIENT_ADDRESS=false
#SECURITY_CLIENT_ID - The client ID assigned to this web service.
SECURITY_CLIENT_ID=service_fmejobsubmitter
#REQUEST_DATA_DIR - The directory which stores request data from HTTP POST body
REQUEST_DATA_DIR=C:/ProgramData/Safe Software/FME Server//resources/system/temp/requestdata
#ENGINE_SUBSECTION - The subsection name used for workspace transformation
ENGINE_SUBSECTION=JOB_SUBMITTER_SERVICE
#LOCALE - the locale of the service.
# If no value, then the default system locale is used.
# If specified, the specified locale is used. The language, country and variant are separated by
# underscores. Language is always lower case, and country is always upper case.
# Examples: "en", "de_DE", "_GB", "en_US_WIN", "de__POSIX", "fr__MAC"
LOCALE=
#FAILOVER_SERVER_NAMES - an optional list of space-separated FME Server host names. Two and only two host names are
# supported. Each host named must be running an FME Server. If this service cannot connect to
# (or loses its connection to) its primary FME Server, it will attempt to connect to the first
# FME Server system named in the list. If connection failure is similarly encountered with this
# system, this service will then attempt to connect to the next system in the list.
# After this, a subsequent connection failure will trigger a final attempt by this service to
# connect to the original, primary FME Server system again. If this also fails, this service
# returns an error message to the client.
# To use FAILOVER_SERVER_NAMES below, uncomment the line and replace <namelist> with a
# space-separated list of two FME Server host names. Do not include the angle-brackets in the
# namelist. For example:
# FAILOVER_SERVER_NAMES=primary secondary
#FAILOVER_SERVER_NAMES=<namelist>
# These are optional notifications that can be configured for this Servlet.
# The general configuration format is NOTIFY_<keyword>=<topic_name>.
# NOTIFY_ASYNC_JOB_SUCCESS - This generates a notification for all successful asynchronous (non-blocking) jobs.
# NOTIFY_ASYNC_JOB_FAILURE - This generates a notification for all failed asynchronous (non-blocking) jobs.
# NOTIFY_SYNC_JOB_SUCCESS - This generates a notification for all successful synchronous (blocking) jobs.
# NOTIFY_SYNC_JOB_FAILURE - This generates a notification for all failed synchronous (blocking) jobs.
NOTIFY_ASYNC_JOB_SUCCESS=JOBSUBMITTER_ASYNC_JOB_SUCCESS
NOTIFY_ASYNC_JOB_FAILURE=JOBSUBMITTER_ASYNC_JOB_FAILURE
NOTIFY_SYNC_JOB_SUCCESS=
NOTIFY_SYNC_JOB_FAILURE=
# CORS Shared Configuration File - File system path to the configuration file for cross-origin resource sharing that
# is itself shared by all FME Server services.
CORS_SHARED_CONFIGURATION_FILE=C:/ProgramData/Safe Software/FME Server//localization/clients/cors.properties
################### Job Submitter Servlet configuration file END #####################
