Data Streaming Service
The Data Streaming service accepts and carries out transformation requests as specified by a workspace, returning the results as a data stream, instead of providing a link to it.
This service provides data feeds for various clients in formats such as GeoRSS, GeoJSON, GML and KML. The MIME type header is returned with the data wherever possible.
Note: You must install this service if you are also installing the KML Network Link service.
Data Streaming service requests are made as either URL or form requests. For example:
http://<host>/fmedatastreaming/<repository>/<workspace>.fmw?<parameters>
The resulting dataset is one file only. After the translation has finished, this dataset is streamed with the appropriate content-type (mime-type) over HTTP back to the client making the request. For example, a web browser or Google Earth are clients that could make the request.
The Data Upload Service works in conjunction with the Data Download, Data Streaming, and Job Submitter services to upload files.
Requirements
The streaming service can accept workspaces that write single or multiple files. If the output contains more than one file, the service creates and streams a zip file containing all output files. No published parameters are required.
Note: Output can include workspaces that write HTML, PNG, KML, GeoRSS, GeoJSON, PDF, and others.
Service Specific Request Parameters
Name |
Value |
Description |
opt_responseformat |
xml | json |
Defines the language of the response. The text must be all lowercase. |
| opt_geturl | The URL to a dataset | The URL of the source dataset to be used for transformation |
| opt_showresult | true | false | It indicates whether the XML/JSON responses from these three services include the FME transformation result. The default value is true if this parameter is not present. |
Using Remote Data During a Request
Using data from HTTP POST body as Reader dataset
This web service can receive data and override source dataset via HTTP POST. The content of the POST request body will be saved to a temporary file which will be used as the Reader dataset of the workspace. If there is more than one reader in the workspace, then you will need to indicate which reader will use the temporary file. You indicate your choice when publishing the workspace by editing the service registration.
Using data from HTTP GET as Reader dataset
This web service can receive data and override Reader dataset via HTTP GET. The dataset should be specified as a URL and passed to service by 'opt_geturl' parameter. Both HTTP and FTP URLs are supported. If there is more than one reader in the workspace, then you will need to indicate which reader will use the temporary file. You indicate your choice when publishing the workspace by editing the service registration.
For example here is a service request that uses a remote KMZ dataset:
Response Elements
If the response format is specified as XML or JSON, a service failure response may contain the elements shown in the following table.
Element |
Child Elements |
Value |
Description |
statusInfo |
message |
message string |
service failure message |
status |
success | failure |
service status |
fmeTransformationResult |
fmeServerResponse |
FME Server response properties |
FME Server response |
fmeEngineResponse |
FME Engine response properties |
FME Engine response |
See Also
