You are here: Reference Manual > FME Server Console > Command Line Options > Console-Specific Options
These options let you customize some of the server console properties when executing a command. The options are specified as:
opt_<option name> <option value>
The "opt" prefix and the option name must be in lower case.
The supported options include those listed here.
opt_fmeServerHost
A string (without spaces) identifying the name of a host running an FME Server with which the FME Server Console should communicate.
This option is different from the fmeHost option, which is described in Console-Specific Transformation Manager Directives.
opt_fmeServerPort
An integer specifying the port number that the FME Server Console should use to communicate with an FME Server running on OPT_fmeServerHost. A valid port value is between 0 and 65535.
opt_subsectionName
A string (without spaces) identifying the name of a subsection in the FME Server’s configuration file that the FME Server will use for the requested translation.
opt_username
The username that the FME Server Console should use when connecting to the FME Server.
opt_password
The password that the FME Server Console should use when connecting to the FME Server.
