You are here: Administrator's Guide > Other Common Tasks > Working with the System Services > Determining FME Server Processes
Based on your specific environment, you might need to determine if FME Server processes are running or not. To do this, launch the Windows Task Manager and examine its process list. Ensure that the Task Manager is set to show processes from all users.
The following FME Server processes might be listed:
- FMEEngine.exe – one for each running FME Engine
- FMEServer.exe - FME Server Core
- FMEScheduler.exe - FME Server scheduler - requires the core to be running
- FMENotifier.exe – FME Server notifier - requires the Core to be running
FMEPublisher.exe- FME Server PublicationFMERelayer.exe- FME Server Relay ManagerFMESMTPRelay.exe- FME Server Email receiver- FMESubscriber.exe – FME Server subscriber - requires the core to be running
- FMEServer_Service.exe - FME Server Process Monitor - running as a Windows Service
- FMEServer_ApplicationServer.exe – FME Server Web Application Server
- postgres.exe – FME Server Database Server
You can determine which FME Server processes are running by examining the output of:
ps -A | grep -i fme
- fme – one for each running FME Engine
- FMEServer - FME Server Core
- FMEScheduler - FME Server scheduler - requires the core to be running
- FMENotifier - FME Server notifier - requires the core to be running
- FMESubscriber - FME Server subscriber - requires the core to be running
FMERelayer - FME Server Relay Manager
FMESMTPRelay - FME Server Email receiver
FMEWebSocket- FME Server WebSocket ServerFMECleanup- FME Server Cleanup service- tomcat7 – FME Server Web Application Server
- postgres – FME Server Database Server
