FME Transformers: 2025.1
CKANConnector
Connects to a CKAN open data portal to manage datasets and resources.
- Browsing and downloading public datasets hosted on a CKAN portal
- Creating or updating metadata and file-based Resources
The CKANConnector connects to a CKAN open data portal using the CKAN Action REST API to perform various tasks on datasets and their associated resources:
| Action | Task |
Create Dataset |
Create a new CKAN dataset. |
Create Resource |
Create a new CKAN resource associated with an existing dataset by uploading content from a file or attribute, or providing a URL. |
Delete Dataset |
Delete a CKAN dataset and its resources. |
Delete Resource |
Delete a specific resource. |
Download Resource |
Download a resource to a file or attribute. |
List Datasets |
List the details of all datasets on a CKAN portal. |
List Resources |
List the details of all resources of a specific CKAN dataset. |
Update Dataset |
Update the details (metadata) of a specific CKAN dataset. |
Update Resource |
Update the content of a specific resource. |
Features with added attributes, as specified in parameters and according to Action:
| Action | Output |
Create Dataset |
Input feature with a JSON representation of the new dataset. |
Create Resource |
Input feature with a JSON representation of the new resource. |
Delete Dataset |
Input feature unchanged. |
Delete Resource |
Download Resource |
Input feature with details about the downloaded item. |
List Datasets |
Multiple features, one for each dataset in the specified location, with details about the items and JSON representation. |
List Resources |
Multiple features, one for each resource in the specified dataset, with details about the items and JSON representation. |
Update Dataset |
Input feature with a JSON representation of the updated dataset. |
Update Resource |
Input feature with a JSON representation of the updated resource. |
Input features are output here unmodified, in addition to any other output locations (Output or <Rejected>).
CKAN Connection |
Select or create a Web Connection, connecting to the CKAN Web Service. |
Action |
Select an operation to perform. Choices include:
Create Dataset
Name |
Specify the name of the new CKAN dataset. Names must be unique on the CKAN portal and be alphanumeric with no spaces. |
Title |
(Optional) Specify a title for the new dataset. |
Private |
Select a privacy setting:
Author |
(Optional) Provide an author name. |
Author Email |
(Optional) Provide an author email address. |
Maintainer |
(Optional) Provide the name of the dataset maintainer. |
Maintainer Email |
(Optional) Provide the email address of the maintainer. |
License |
(Optional) Specify a dataset license, which may be selected from the options available on the CKAN portal. |
Notes |
(Optional) Provide any notes, comments, or description for the dataset. |
Source |
(Optional) Specify any applicable URL regarding the data source. |
Version |
(Optional) Specify any version information for the dataset. |
Tags |
(Optional) Specify any tags for the dataset, which may be selected from the options available on the CKAN portal. Tags that do not already exist will be created. |
Groups |
(Optional) Specify any groups to assign the dataset to, which may be selected from the options available on the CKAN portal. |
Organization |
Specify the organization that controls the dataset, which may be selected from the options available on the CKAN portal. |
Output Attributes
JSON Response Attribute |
Name the attribute to contain the JSON object representing the dataset. |
Data Source
Data Source |
Select the source type:
Note that folder-based formats and datasets with multiple files can be zipped and uploaded as one File. |
File to Upload |
When Data Source is File, specify the file to be uploaded. |
Attribute to Upload as File |
When Data Source is Attribute, specify the attribute containing the content for upload. |
Upload with File Name |
When Data Source is Attribute, specify the filename, including extension, to contain the uploaded content. |
URL |
When Data Source is URL, provide the URL of the resource. |
Resource Metadata
Dataset |
Specify the ID of the dataset to contain the new resource. |
Name |
(Optional) Provide a name for the resource. If not specified, the filename or URL basename is used. |
Description |
(Optional) Provide a description of the resource. |
Format |
(Optional) Specify the file format of the resource. |
MIME Type |
(Optional) Specify the MIME type of the uploaded file or resource URL. If not specified, the type is inferred from the filename or URL. |
Output Attributes
Name the attribute to contain the JSON object representing the resource. |
Delete Dataset
Dataset |
Specify the ID of the CKAN dataset to delete, along with its resources. |
Purge |
Select a deletion method:
Output Attributes
No attributes are added for this Action.
Delete Resource
Dataset |
Specify the ID of the dataset containing the resource to delete. |
Resource |
Specify the ID of the resource to delete. |
Output Attributes
Content Source
Dataset |
Specify the ID of the dataset containing the resource to download. |
Resource |
Specify the ID of the resource to download. |
Destination
Download As |
Select a destination type for downloaded items:
Download to Attribute |
When Download as is Attribute, specify the attribute to contain the contents of the downloaded item. |
Download to Folder |
When Download as is File, specify the path to the folder that will store the downloaded item. |
If File Exists |
When Download as is File, select a method for handling existing files:
Output Attributes
Attributes to Add |
Select any available attributes to be included on the output features:
Output Attributes
Attributes to Add |
List Resources
Dataset |
Specify the ID of the dataset to list the resources of. |
Output Attributes
Attributes to Add |
Update Dataset
Current metadata values are preserved unless a new value is provided. To clear an existing value, set it to null.
Dataset ID |
Specify the ID of the dataset to update. |
Name |
(Optional) Specify the name of the new CKAN dataset. Names must be unique on the CKAN portal and be alphanumeric with no spaces. |
Title |
Private |
(Optional) Select a privacy setting:
Author |
Author Email |
Maintainer |
Maintainer Email |
License |
Notes |
Source |
Tags |
Groups |
Organization |
(Optional) Specify the organization that controls the dataset, which may be selected from the options available on the CKAN portal. |
Output Attributes
Data Source
Data Source |
File to Upload |
URL |
Resource Metadata
Dataset |
Specify the ID of the dataset containing the resource. |
Resource |
Specify the ID of the resource to update. |
Name |
(Optional) Provide a name for the resource. |
Description |
Format |
MIME Type |
(Optional) Specify the MIME type of the uploaded file or resource URL. |
Output Attributes
| Dependencies | |
Search for all results about the CKANConnector on the FME Community.
