FME Transformers: 2025.1
Categories
Web
Web
Related Transformers
AmazonAthenaConnector
AzureAIVisionConnector
AzureTextAnalyticsConnector
ComprehendConnector
GoogleLanguageConnector
GoogleVisionConnector
S3Connector
SQSConnector
RekognitionConnector
Connects to Amazon Rekognition for object detection in images.
Jump to Configuration
  • Submitting images to the Amazon AWS Rekognition service to
    • detect individual objects
    • describe the general contents
    • extract small amounts of text
    • detect faces and facial descriptions in an image
    • detect explicit or suggestive adult content in an image
    • detect PPE (Personal Protective Equipment) in an image
The RekognitionConnector uses your Amazon AWS account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the computer vision service.
It will submit images to the service, and return features with attributes that describe the contents of the image. Object detection, text detection, and face detection can be performed.
  • For object detection, if the service is able to identify the exact location of an object in the image, a bounding box geometry will also be returned.
  • Text detection and face detection always return bounding boxes around the detected text or face.
  • Image moderation will return the input feature, with moderation labels added when unsafe content is detected.
Each input image may result in several output features.
Optional Input Port
This transformer has two modes, depending on whether a connector is attached to the Input port or not:
  • Input-driven: When input features are connected, the transformer runs once for each feature it receives in the Input port.
  • Run Once: When no input features are connected, the transformer runs one time.
When the Input port is in use, the Initiator output port is also enabled.
  • For better performance, requests to the Rekognition service are made in parallel, and are returned as soon as they complete. Consequently, detection results will not be returned in the same order as their associated requests.
  • The RekognitionConnector is able to extract up to 50 words per image when performing text detection. This makes it unsuitable for detecting full pages of text, as from a scanned document.
  • While powerful, the use of AI has important legal and ethical implications. Consult your local AI legislation and ethical guidelines before applying the RekognitionConnector in a production environment.
  • For an overview of Rekognition's capabilities and limitations, please see Amazon's FAQ on the topic: https://aws.amazon.com/rekognition/the-facts-on-facial-recognition-with-artificial-intelligence
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies Amazon AWS Account with Rekognition access
Aliases AmazonAWSRekognitionConnector
History Released FME 2019.2
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the RekognitionConnector on the FME Community.
