FME Transformers: 2025.1 BETA
SQSConnector
Connects to the Amazon Simple Queue Service to send and receive messages.
- Aggregation of data from queues and other message streams
- Trigger an action from a message
The SQSConnector uses your Amazon AWS account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the queue storage service.
The output of this transformer will vary depending on the action performed. Message data and metadata are presented as feature attributes.
On a Receive action, when Action is set to Receive and the Receive Mode is set to either Stream or After a Fixed Number of Messages, heartbeat features will be output through this port. Heartbeat features will have two output attributes:
- _heartbeat_id: Integer starting at 0. This is a unique identifier for each heartbeat feature output from this port.
- _heartbeat_counter: Integer starting at 0 that resets whenever the connector receives a new message and a new period of inactivity begins. This counter represents the number of consecutive heartbeat features.
See Heartbeat for more details.
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Note If a feature comes in to the SQSConnector already having a value for fme_rejection_code, this value will be removed.
Credential Source |
Credentials can be used from different sources. Using a web connection integrates best with FME, but in some cases, you may wish to use one of the other sources.
Account |
Available when the credential source is Web Connection. To create an Amazon Web Services connection, click the 'Account' drop-down box and select 'Add Web Connection...'. The connection can then be managed via Tools -> FME Options... -> Web Connections. |
Region |
The AWS Region in which the specified Queue resides. Overrides the region set in the web connection if specified. |
Alternate Endpoint |
Available when Credential Source is not Web Connection. If specified, use an alternate SQS-compatible API. These are typically queue services from providers other than AWS, or on-premises solutions. |
Embedded Credentials |
Available when the credential source is Embedded. An access id and secret key can be specified directly in the transformer instead of in a web connection. |
Queue |
Specify the queue name to send to or receive from. A queue can be entered manually, or selected interactively by clicking the ellipses. |
Action |
The type of operation to perform. Choices are:
No options. Returns the count of messages in a queue.
Deletes messages from the queue.
Delete Options
Message Receipt Handle |
Required for deleting a message. Retrieved from a previous receive operation. |
Receives messages from the front of the queue.
Receive Options
Mode |
The following message receiving options are available:
Maximum Messages to Read |
For the After a Fixed Number of Messages option, specifies the number of messages to read. |
Delete on Receive |
If Yes, then delete the messages as soon as they are received from the queue. If No, the messages can be received again after the visibility timeout. |
Receive Request Attempt Id |
Only for FIFO Queues. Used to resend a receive request the same way as a previous attempt id, ignoring the visibility timeout. |
Visibility Timeout (seconds) |
The time the message is invisible. After the timeout expires, the message is visible. The default is 30 seconds. |
Heartbeat
When Action is set to Receive and the Receive Mode is set to either Stream or After a Fixed Number of Messages, a heartbeat feature is output through the Heartbeat port after a period of inactivity. The length of this period is determined by the following parameters:
Interval |
The period of inactivity before a heartbeat feature is emitted, in units specified by the Time Unit parameter. Defaults to 1. |
Time Unit |
The unit for Interval.
Defaults to Hours. |
Send Options
Content |
An encoded message. The default encoding is an xml unicode string. |
Message Delay (seconds) |
The time before a message is visible on the queue. |
Is Queue FIFO |
Whether the Queue is FIFO. |
Message Group Id |
The tag that specifies that a message belongs to a specific message group. Messages that belong to the same message group are always processed one by one, in a strict order relative to the message group (however, messages that belong to different message groups might be processed out of order). |
Message Deduplication Id |
The token used for deduplication of sent messages. If the queue has ContentBasedDeduplication enabled, this parameter is optional. If a message with a message deduplication ID is sent successfully, any messages sent with the same message deduplication ID are accepted successfully but aren't delivered during the 5-minute deduplication interval. |
Message Attributes
- Attribute Name: The message attribute name can contain the following characters: A-Z, a-z, 0-9, underscore (_), hyphen (-), and period (.)
- Type: Select between StringType, NumberType, or BinaryType
- Value:
- String: Any string value.
- Number: Any number value.
- Binary: Either a binary value or a path to a binary file.
Available attributes vary according to the selected Action.
Attributes to Add |
Select any available attributes to be included on the output features:
Dependencies | Amazon Web Services account |
Aliases | |
History | Released FME 2020.0 |
Search for all results about the SQSConnector on the FME Community.
