FME Transformers: 2025.1
AmazonAthenaConnector
Connects to Amazon Athena to query Amazon S3 datasets.
- Running SQL queries against datasets stored on Amazon S3
The AmazonAthenaConnector uses your AWS account credentials to perform SQL queries against Amazon S3 datasets.
Queries may be saved and re-used.
Query results are both output from the transformer and saved on S3 as a CSV file with accompanying metadata, and may be optionally saved as a table. Note that results are not cleaned up by the transformer, and must be deleted manually when desired.
Athena is very efficient at querying large datasets to retrieve subsets, but is not recommended for retrieving whole datasets.
Note that AWS charges for the following:
- The amount of data scanned. All data is scanned for every query, unless the underlying data supports columnar storage.
- The storage of the source data in S3.
- The storage of the results of each query in S3.
For SELECT queries, one feature per returned row is output here, including any attributes specified in the Exposed Attributes parameter, corresponding to the columns included in the query.
For other types of query where no rows are returned, one feature is output with _bucket and _path attributes added.
Input features are output here unmodified, in addition to any other output locations (Output or <Rejected>).
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute describing the category of the error will be added, along with a more descriptive fme_rejection_message which contains more specific details as to the reason for the failure.
If an Input feature already has a value for fme_rejection_code, this value will be removed.
Credential Source |
Select the type of credentials to use:
Account |
When Credential Source is Web Connection, select or create a Web Connection connecting to an Amazon Web Services Web Service. |
Region |
(Optional) Select the AWS Region in which the S3 dataset resides. This setting will override the region set in the web connection. |
AWS CA Bundle |
(Optional) Provide an AWS CA Bundle specifying the path to a certificate bundle to use for certificate validation. If set, this has precedence over the value of the AWS_CA_BUNDLE environment variable. |
Embedded Credentials |
When Credential Source is Embedded:
Use Named Query |
Select a query provision method:
Named Query |
When Use Named Query is Yes, select a previously-saved query to run. |
Query |
When Use Named Query is No, enter a complete SQL query to run. |
Query Timeout |
(Optional) Specify the number of seconds to wait for a query to successfully complete. If incomplete, the query will be canceled. The default and maximum is 1800 seconds (30 minutes). |
Result Has Column Names |
Select an option for the first row:
Athena generates both a CSV file of the results and an accompanying metadata file.
Bucket |
Specify the S3 bucket in which to save the query results. |
Path |
Specify the full path within the bucket to save the query results. It is not recommended to save results in the same location as the source data. Query results are not deleted by the transformer - they may be deleted manually or saved to a location with default Object Expiration. |
When enabled, the SQL query will be saved to a database and may be reused.
Database |
Specify the database in which to store the query. |
Title |
Provide a name for the saved query. |
Description |
Provide a description of the saved query. |
When enabled, the query results will also be saved to a new database table.
Database |
Specify the database in which to store the table. |
Table Name |
Provide a table name. |
Description |
(Optional) Provide a description. |
Output Bucket |
Specify the S3 bucket in which to save the table. |
Output Path |
Specify the full path within the bucket to save the table. This location must be empty. |
Format |
Select a format for the table data:
When running a SELECT query, the column names are not automatically exposed as attributes on the output features.
Add the column names to this table and they will be exposed in table order.
Dependencies |
Amazon Web Services account |
Aliases |
History |
Released FME 2019.2 |
Search for all results about the AmazonAthenaConnector on the FME Community.
