FME Transformers: 2025.1
ComprehendConnector
Connects to Amazon AI Comprehend for natural language processing on text.
- Submitting text to the Amazon AWS Comprehend service for analysis to:
- Detect dominant language
- Determine sentiment information
- Detect key phrases
- Detect entities
The ComprehendConnector uses your Amazon AWS account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the natural language processing service.
It will submit text to the service, and return features with attributes about that text. Each input text feature may result in several output features.
Optional Input Port
This transformer has two modes, depending on whether a connector is attached to the Input port or not:
- Input-driven: When input features are connected, the transformer runs once for each feature it receives in the Input port.
- Run Once: When no input features are connected, the transformer runs one time.
When the Input port is in use, the Initiator output port is also enabled.
- For better performance, requests to the Comprehend service are made in parallel, and are returned as soon as they complete. Consequently, detection results will not be returned in the same order as their associated requests.
- All confidence scores are returned between 0 and 1. For more information about accuracy, see the Amazon Comprehend FAQs: https://aws.amazon.com/comprehend/faqs/
Output will depend on the analysis chosen.
Language Detection
Detects the dominant language for text. The service may return multiple language guesses for an individual request.
Attributes
_language_code |
The language code guessed for the text. A list of available languages is available at: https://docs.aws.amazon.com/comprehend/latest/dg/supported-languages.html |
_confidence |
The probability that a given prediction is correct. |
| _text |
The text analyzed. |
Sentiment Detection
Detects the sentiment for text.
Attributes
_sentiment |
The sentiment for the text. Possible values are:
_sentiment_postive |
The confidence score for positive sentiment. |
_sentiment_negative |
The confidence score for negative sentiment. |
_sentiment_neutral |
The confidence score for neutral sentiment. |
_sentiment_mixed |
The confidence score for mixed sentiment. |
_text |
Key Phrase Detection
Detects the key phrases in text.
Attributes
_key_phrases{}.text |
The key phrases from the text. |
_key_phrases{}.confidence |
A number between 0 and 1 that indicates the confidence score for the key phrase. |
_key_phrases{}.begin_offset |
The key phrase beginning offset in the text. |
_key_phrases{}.end_offset |
The key phrase ending offset in the text. |
_text |
Entity Detection
Detects the entities in text. The service can return multiple entities in a given text.
Attributes
_entities{}.text |
The entity from the text. |
_entities{}.confidence |
A number between 0 and 1 that indicates the confidence score for the entity. |
_entities{}.begin_offset |
The entity beginning offset in the text. |
_entities{}.end_offset |
The entity ending offset in the text. |
_entities{}.type |
The type of the detected entity. Types can be found here: https://docs.aws.amazon.com/comprehend/latest/dg/how-entities.html |
_text |
When the optional Input port is used, input features are output here unmodified, in addition to any other output locations (Output or <Rejected>).
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Credential Source |
The ComprehendConnector can use credentials from different sources. Using a web connection integrates best with FME, but in some cases, you may wish to use one of the other sources.
Account |
Available when the credential source is Web Connection. To create a Comprehend connection, click the 'Account' drop-down box and select 'Add Web Connection...'. The connection can then be managed via Tools -> FME Options... -> Web Connections. |
Region |
The AWS Region through which to access Comprehend. To optimize latency, it is best practice to specify the correct region. |
Access Key and Secret Access Key |
Available when the credential source is Embedded. An access key ID and secret access key can be specified directly in the transformer instead of in a web connection. |
Text |
The text to be analyzed under the specified request action. |
Action |
The type of operation to perform. Choices are:
Language |
This parameter is available when the Action parameter is Entity Detection, Key Phrase Detection, or Sentiment Detection. This parameter specifies the language of the text. All text must be in the same language per transformer. If using an attribute value, it must be the language code (for example, βenβ). Reference for supported languages: https://docs.aws.amazon.com/comprehend/latest/dg/supported-languages.html |
| Dependencies | Amazon AWS Account with Comprehend access |
| Aliases | AmazonAWSComprehendConnector |
| History | Released FME 2019.2 |
Search for all results about the ComprehendConnector on the FME Community.
Examples may contain information licensed under the Open Government Licence β Vancouver, Open Government Licence - British Columbia, and/or Open Government Licence β Canada.
