FME Transformers: 2025.1
CesiumIonConnector
Connects to Cesium ion to manage assets.
- Managing assets on Cesium ion by uploading and deleting
The CesiumIonConnector uses your Cesium ion account credentials to access the service and perform various tasks:
| Action | Task |
Delete |
Delete assets. |
Upload |
Upload a folder containing one of :
Optional Input Port
This transformer has two modes, depending on whether a connector is attached to the Input port or not:
- Input-driven: When input features are connected, the transformer runs once for each feature it receives in the Input port.
- Run Once: When no input features are connected, the transformer runs one time.
Features with added attributes, as specified in parameters and according to Action:
| Action | Output - Input-Driven | Output - Run Once |
Delete |
Input feature unchanged. |
One new feature. |
Upload |
Input feature with details about the uploaded item. |
New feature with details about the uploaded item. |
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute describing the category of the error will be added, along with a more descriptive fme_rejection_message which contains more specific details as to the reason for the failure.
If an Input feature already has a value for fme_rejection_code, this value will be removed.
Cesium ion Account |
Select or create a Web Connection, connecting to the Cesium ion Web Service. |
Action |
Select an operation to perform. Choices include:
Options
Asset ID |
Specify the Cesium ion asset to delete. |
Options
Source Folder |
Specify the folder to upload as an asset. The folder should contain one of :
Asset Name |
Specify a name for the new asset. |
Asset Description |
(Optional) Provide a description of the new asset. |
Wait Behavior
Wait for ion Processing |
Select an option for upload processing:
Processing Timeout (s) |
When Wait for ion Processing is Yes, specify the amount of time in seconds to wait for the asset to complete processing. The translation will still succeed if the timeout is reached, but the uploaded asset is not guaranteed to be ready for use. |
Manual Georeferencing
If the new asset is an unreferenced OBJ file, enable this to manually assign positional information.
Latitude (Degrees) |
Specify latitude in decimal degrees. |
Longitude (Degrees) |
Specify longitude in decimal degrees. |
Height (Meters) |
Specify elevation in meters. |
Added Attributes
Output features will receive these attributes:
_cesiumion_url |
The URL of the new asset |
_cesiumion_id |
Numerical ID of the new asset |
_cesiumion_user_id |
ID of the user account |
_cesiumion_type |
The type of asset. One of 3DTILES, IMAGERY, or TERRAIN. |
_cesiumion_name |
The name of the new asset |
_cesiumion_description |
The description for the new asset |
_cesiumion_bytes |
Number of bytes uploaded |
_cesiumion_date_added |
Date the asset was added |
_cesiumion_status |
Cesium ion processing status. One of NOT_STARTED, IN_PROGRESS, COMPLETE or ERROR |
_cesiumion_percent_complete |
Processing percent complete |
| Dependencies | Cesium ion Account |
| Aliases | BentleyCesiumIonConnector |
| History | Released FME 2019.0 |
Search for all results about the CesiumIonConnector on the FME Community.
