FME Transformers: 2025.1
Categories
Integrations
Web
Web
Workflows
Related Transformers
AzureAIVisionConnector
AzureBlobStorageConnector
AzureQueueStorageConnector
AzureTextAnalyticsConnector
BoxConnector
CesiumIonConnector
DropboxConnector
GoogleCloudStorageConnector
GoogleDriveConnector
HDFSConnector
OneDriveConnector
ProjectWiseWSGConnector
S3Connector
AzureFileStorageConnector
Connects to Azure Files to manage files and folders.
Jump to Configuration
  • Managing datasets on Azure Files by uploading, downloading, and deleting files and folders
  • Transferring file contents into or out of an attribute in FME
  • Retrieving file and folder names, paths, links and other information from Azure Files to use elsewhere in a workspace
The AzureFileStorageConnector uses your Azure Storage account credentials to perform various management tasks on Azure Files:
Action Task
Delete
Delete files and folders.
Download
Download a file or folder to an attribute, file, or folder.
List
List the item details for the contents of a folder.
Upload
Upload a file, folder, or the contents of an attribute.
Once valid account credentials have been provided, you may browse to available content for the selected Action.
Optional Input Port
This transformer has two modes, depending on whether a connector is attached to the Input port or not:
  • Input-driven: When input features are connected, the transformer runs once for each feature it receives in the Input port.
  • Run Once: When no input features are connected, the transformer runs one time.
When the Input port is in use, the Initiator output port is also enabled.
  • This transformer cannot move or copy files between different locations. Consider using multiple connectors for these tasks, by downloading files/folders and re-uploading them to a new location.
  • The FeatureReader can access Azure File Storage directly but does not download a local copy of the dataset.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies Azure Storage Account
Aliases MicrosoftAzureFileStorageConnector
History Released FME 2019.0
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the AzureFileStorageConnector on the FME Community.
