FME Transformers: 2025.1 BETA
Categories
Integrations
Web
Web
Workflows
Related Transformers
AzureBlobStorageConnector
AzureFileStorageConnector
BoxConnector
CesiumIonConnector
DropboxConnector
GoogleCloudStorageConnector
GoogleDriveConnector
HDFSConnector
ProjectWiseWSGConnector
S3Connector
OneDriveConnector
Connects to Microsoft OneDrive to manage files and folders.
Jump to Configuration
  • Manage datasets on Microsoft OneDrive by uploading, downloading, and deleting files and folders
  • Transfer a file's contents (such as XML or raster) into or out of an attribute in FME
  • Read downloaded Microsoft OneDrive data using the FeatureReader, or upload data written by the FeatureWriter to Microsoft OneDrive
  • Retrieve file and folder names, paths, links and other information from Microsoft OneDrive to use elsewhere in a workspace.
The OneDriveConnector uses your Microsoft OneDrive account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the file storage service. This connector is compatible with OneDrive personal and OneDrive for Business accounts.
Depending on your choice of actions, it will upload or download files, folders, and attributes; list information from the service; or delete items from the service. On uploads, link attributes are added to the output features. On List actions, links and file/folder information are added as attributes.
  • This transformer cannot be used to directly move or copy files between different Microsoft OneDrive locations. However, multiple OneDriveConnectors can be used to accomplish these tasks.
  • The FeatureReader can access Microsoft OneDrive directly (without using the OneDriveConnector), however, a local copy of the dataset will not be created.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies Microsoft OneDrive account
Aliases
History Released FME 2017.0
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the OneDriveConnector on the FME Community.
