Administrator's Guide
Notices
Version Information
About This Guide
About FME Server
Planning an FME Server Installation
Planning for Fault Tolerance
Planning for Disaster Recovery
Planning for Scalability
Installing FME Server: Before You Begin
System Requirements
Obtaining the Installer
Requirements for FME Workspaces
Default User Accounts and Passwords
Installation Options
Express Installation (Windows)
Express Installation (Linux)
Distributed Installation
Engine Installation
Silent Installation (Windows)
Silent Installation (Linux)
Upgrading FME Server
FME Engine Only Upgrade
Optimizing FME Server
Configuring the Number of FME Engines to Start
Adding FME Engines on a Separate Machine
Changing the Database Provider for the FME Server Database
Moving the Web Applications Server to Another Machine
Outputting the Log File to a Local Directory in a Distributed Environment
Securing FME Server
Overview of Securing FME Server
Role-Based Access Control
Securing FME Server and Applications/Services
Connecting to Active Directory
Configuring Integrated Windows Authentication
Running the System Services Under Different Accounts
Using FME Server with a Proxy Server
Hiding External Content in the Web User Interface
Other Common Tasks
Request and Install a License
Configuring the FME Engine
Sharing FME Engine Resources
Adding and Modifying Resources Directories
Working with the System Services
Configuring FME Server to Receive E-mail
Configuring FME Server to Send E-mail Notifications
Sending Jobs to Specific Engines with Job Routing
Configuring Job Recovery
Performing a Scheduled Backup of an FME Server Configuration
Migrating an FME Server Configuration
Purging Logs and History
Changing the Web Application Server Host Name and Port
Configuring International Character Encoding
Changing the File System to Another Machine
Configuring Native OGC Services Support
General Troubleshooting
Unable to Run Workspaces Registered to Notification Service When SSL is Configured
FME Server Fails to Fully Start on Linux When Configured to Use Oracle Database
Reference Manual
Notices
FME Server Architecture
FME Server Configuration Files
processMonitorConfigCore.txt
processMonitorConfigEngines.txt
fmeServerConfig.txt
fmeCommonConfig.txt
fmeWebSocketConfig.txt
FME Server Log Files
Message Logger Properties
API Quick-Find
FME Server Services
Transformation Services
OGC Services
Utility Services
Authentication and Authorization
FME Server Engines
Configuration File Layout
Pseudo Variables
Licensing the FME Engine
FME Server Core
Transformation Manager
Repositories
Resources
Native Session-Based Chat Protocol
FME Server Process Monitor
FME Server Console
Starting the FME Server Console
Modes
Directives
Command Line Options
Web User Interface
FME Server Web Interface
Preparing to Use the Web Interface
Accessing the Web Interface
Account Management
Logging In to the Web Interfaces
Changing the Login Password
Logging Out
General Features
User Session Information
Server Information
About Times and Time Zones
Using the Interface
Workspaces
Database Connections
Schedules
Notifications
Jobs
Resources
CORS
Engines & Licensing
Backup & Restore
Security
Services
System Cleanup
All Files
Notices
Version Information
You are here:
Notices
Version Information
Version Information
FME Server 2016
is Version
7.19
of the FME software.
