FME Engine Only Upgrade
FME Engine is the component of FME Server that performs the actual data translations and transformations. At times, you might want to upgrade only your FME Engines and not any other FME Server components. For example, you might want to provide support for recently added formats or other newer functionality included in a new release of FME without upgrading other FME Server components.
The procedure described in this section uses the standard FME installer provided on the Safe Software web site and can be performed with an official or beta release of the FME Engine installer.
In this Section
