FME Transformers: 2026.2
Categories
Coordinates
Integrations
Related Transformers
AttributeReprojector
CommonLocalReprojector
CsmapAttributeReprojector
CsmapReprojector
EsriReprojector
GridInQuestIIReprojector
GtransReprojector
PROJAttributeReprojector
PROJReprojector
ReframeReprojector
ReprojectAngleCalculator
ReprojectLengthCalculator
Reprojector
GtransAttributeReprojector
Reprojects coordinates stored as attributes from one coordinate system to another using the Gtrans reprojection engine from the National Land Survey of Sweden (Lantmäteriet).
Jump to Configuration
  • Reprojecting features when explicitly using the Gtrans library is desired
  • Adding additional coordinate pairs as attributes, in alternate coordinate systems
The GtransAttributeReprojector accepts any feature. The user specifies the attributes containing X and Y Coordinates, and selects a Transformation File to reproject them from one coordinate system to another, using the Gtrans engine.
Gtrans is widely used for coordinate transformation within Sweden as it is officially recommended, translates between numerous local coordinate systems, and supports rubbersheeting transformations.
The transformation is configured by selecting a Gtrans Translation File appropriate for the Source and Destination Coordinate System.
Translation Files
A selection of Gtrans Translation Files are provided with FME.
Only reprojections defined here or with a user-provided Gtrans Translation File (see below) may be performed with this transformer.
File Type
Description
Location
*.tf, *.tfi
Translation File - a text file containing parameters defining a reprojection from one coordinate system to another.
  • *.tf - forward reprojection
  • *.tfi - inverse reprojection of the tf file with the same name.
[FME Install Directory]\Reproject\Gtrans\Sys
*.tr1, *.tr2
Triangulation File - a binary file used for the interpolation of residuals.
  • *.tr1 - forward
  • *.rf2 - inverse of the *.tr1 file with the same name.
Each *.tf/*.tfi file corresponds to a line item in the Gtrans Translation Files library accessed in the parameters dialog.
Note that when using the Filter option, FME searches the file names of the *.tf/*.tfi files - not the Source and Destination Coordinate Systems.
Geoid Files
When reprojecting between geoids, this transformer needs additional resource files.
File
Description
Location
geoid.def
Geoid Definition File - a text file containing parameters describing geoids. A default version is provided with FME.
User-provided geoids may also be used - see below.
*.grd
Binary Grid files for specific geoids.
Gtrans User Data
Users may provide their own transformations and definitions by placing the appropriate files as directed:
File(s)
Description
Location
*.tf, *.tfi
The Translation File should reference the correct geoid.def and any required *.bin files.
User-defined translations are placed in the same location as the provided Translation Files.
geoid.def
The user version of this file is placed in a different location than the default geoid.def provided with FME.
[FME Install Directory]\Reproject\Gtrans\Arkiv
*.bin
  • This transformer does not change the feature's coordinates – it only changes the values of the selected X and Y attributes (if they contain coordinate values).
  • FME has a Workspace Parameter, Reprojection Engine, that may be set to either FME (CS-Map) or Esri. This transformer will override this parameter setting.
  • The AttributeReprojector provides similar functionality, and will use the default library (CS-Map or Esri) set in FME. It supports some Swedish coordinate systems, but will not use the Gtrans definitions or reprojection engine.
  • To reproject coordinates stored as geometry, consider using the GtransReprojector.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies Gtrans software and Translation Files, included with FME.
Operating System Restrictions
Win64, Win32, and Linux are supported. Not available on Mac.
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the GtransAttributeReprojector on the FME Community.
Example contains data © OpenStreetMap contributors.
Keywords: SWEREF99 "National Land Survey of Sweden" Sweden
