FME Transformers: 2025.2
Categories
Geometries
Related Transformers
Intersector
LineBuilder
LineCloser
LineExtender
PathBuilder
Snapper
LineCombiner
Connects line features that meet at common start or end points to create longer lines or paths.
Jump to Configuration
  • Connecting multiple lines into longer, continuous lines or paths
The LineCombiner receives features with line geometry and merges them where they meet at the same start or end x and y coordinates, producing a continuous line or path, depending on parameter choices and input feature properties.
Attribute values can be optionally used to group the input features to be combined, with various options for attribute accumulation including the creation of List attributes .
Z Values
Z values are supported and optional. The Consider Node Elevation parameter dictates how they are handled:
  • If Yes, nodes will only be combined if the x, y, and z coordinates are an exact match.
  • If No, nodes are combined where the x and y coordinates are a match, and the z values are further handled according to the Connect Z Mode parameter.
Junctions, Intersections, and Crossings
Input line features may cross and intersect in numerous ways, and their handling depends on a combination of parameters.
Crossings
A simple crossing, where no vertices exist at the point of intersection, is handled as if the lines do not interact at all. There are no junctions.
Input
Lines have a Name attribute, either A or B.
They cross but do not intersect.
Output: 2 Lines
Two lines are output.
Parameter settings:
Combine on Attributes: None
or
Combine on Attributes: Name
Intersections/Junctions
The LineCombiner cannot connect more than two lines at a single node. Combinations are determined by the Combine On Attributes and Junctions parameters.
Input
They intersect, having a node in common where they meet.
This junction has four line segments converging.
Output: 2 Lines
Two lines are output, each passing through the junction.
Parameter settings:
Junctions: Consider Attribute Values
Output: 4 Lines
Four lines are output, each terminating at the junction.
Parameter settings:
Junctions: Ignore Attribute Values
or
Combine on Attributes: No items selected.
or
Mid-line Intersections
Where a line meets another at a point along the line (not an end point), the Input Feature Topology parameter determines the output.
Both features must have a vertex in common.
Input
Two lines are input, with the attribute Name either A or B.
They meet as a T intersection, where B touches A mid-line.
Both lines have a vertex at that location.
Output: 2 Lines
Two lines are output unchanged.
Parameter settings:
Input Feature Topology: End Noded
Output: 3 Lines
Three lines are output. Input line A is split at the junction.
Parameter settings:
Input Feature Topology: Vertex Noded
Output Lines and Paths
Output features are either lines or paths, depending on both parameters and the properties of the input features.
Lines are output unless paths are required. When lines are created, the matching combined nodes are collapsed into a single node (pseudonodes are removed).
Paths retain all input nodes, keeping the input features intact as segments in a longer complex path geometry. Paths are output if Preserve Lines as Path Segments is Yes, or if the input geometry has properties that vary, such as measures, traits or geometry labels.
Duplicate input features are discarded.
Note that path geometry is not supported in all output formats. See also: Line and Path geometry.
Creating and Modifying Linear Features
These transformers work with lines in a variety of ways.
Processing Behavior
Group-Based
Feature Holding
Yes
Dependencies None
Aliases PseudoNodeRemover, LineJoiner
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the LineCombiner on the FME Community.
