FME Transformers: 2025.2
Categories
3D
3D
Workflows
Related Transformers
2DGridCreator
PointCloudCreator
RasterNumericCreator
RasterRGBCreator
Creator
Creates features using the parameters supplied, and sends them into the workspace for processing.
The Creator's interface allows you to select the desired type of geometry, then enter the coordinates and/or parameters that will create the desired object.
This transformer does not have any input ports.
Processing Behavior
Not applicable
Feature Holding
Not applicable
Dependencies None
Aliases 2DCreator 3DCreator Creator3D
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the Creator on the FME Community.
