FME Transformers: 2024.2
RasterToPolygonCoercer
Creates polygons from input raster features. One polygon is output for each contiguous area of cells with the same value in all bands.
- Converting raster images to a set of polygons.
- Vectorizing raster data for vector geoprocessing.
The RasterToPolygonCoercer accepts raster input features. Polygons are traced around the edges of cells (pixels), enclosing areas with identical band values. Donuts are created where contiguous areas contains islands of differing values.
Nodata cells may either be included or excluded.
Output polygons may retain the raster’s attributes, and may also have a new Label Attribute added, containing the band values represented as a comma-separated list.
This transformer supports raster band selection. The RasterSelector can be used to modify selection.
In this example, we will vectorize a DEM dataset. The original data is represented as a single band numeric raster. The band values represent elevation in meters.
The raster is routed into a RasterToPolygonCoercer.
In the parameters dialog, we keep the default settings - discarding Nodata values, preserving attributes, and creating a new Label attribute which will contain the band values.
Polygons are produced, surrounding areas with identical band values. Donuts are produced where necessary. Note the new _label attribute, with the band value.
In this source data, the elevation intervals are one meter, producing a large number of small polygons. These polygons can be grouped together and dissolved, using an AttributeRangeMapper and a Dissolver to produce generalized polygons, as shown. The ranges used here are 10 meters each.
- If memory usage becomes an issue while using this transformer, try adding a RasterCheckpointer before the RasterToPolygonCoercer.
- If you need a polygon for each pixel in the raster, consider using the RasterCellCoercer.
Choosing a Raster Transformer
Working with Rasters
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
Vectors and Rasters
Polygons and donut polygons produced by tracing around contiguous areas of identical cell (pixel) values.
INVALID_GEOMETRY_DIMENSION
Extract Nodata Values |
Specifies whether polygons will be output for Nodata areas in the raster. A cell is considered to be Nodata when, for each selected band, the value for that cell is equal to that band's Nodata value. If any cell value is not equal to that band's Nodata value, the cell will be considered data. |
Preserve Attributes |
Specifies whether the output vector features should retain attributes from the input raster feature. |
Label |
Specifies the name of an attribute that will be created on every output feature describing the polygon. The label will be a comma-separated list of the band values covered by that polygon. For example, the label for a raster with three bands might be something like 64,128,255 whereas a single-band numeric or DEM raster label might be a single integer. |
Search for all results about the RasterToPolygonCoercer on the FME Community.
